Problem with Dewalt DW735 Height Adjustment
Dale Critchlow
>The height adjustment on my Dewalt DW735 planer is binding. I can barely crank it up and down. I have tried lubricating it with WD40 but it only helps a little. Suggestions?
Thanks,
Dale
Re: Problem with Dewalt DW735 Height Adjustment
Check For Wood Chip Build Up Inside The Planer
Dave's Not Here
>I agree, clean it thoroughly. Blow and or vac it out.
WD40 is not really a lubricant. Try to find some of the dry lube type stuff that will not be wet and attract dust. You may have to use some WD40 as cleaning fluid to clean the posts and the threaded rods thoroughly and then lube them with graphite or other dry lube. I have the older version with the knives you can sharpen and I have cleaned it several times. WD40 and lots of paper towels. Wet everything that screws or slides and run it up and down and wipe everything off, over and over and then lube it. Repeat in a year or two.
Any chance the head lock in partly engaged?
Dave Bair, Eaton Rapids, MI
Re: Check For Wood Chip Build Up Inside The Planer
Dale Critchlow
>You were right. The chain gear in one corner was packed with sawdust. I cleaned it out and that solved the problem.
Thanks,
Dale
