Does anything dissolve silicone caulking?
John in NM
>Trying to get a lens out of a metal eyepiece housing, and its been siliconed (not siliconized acrylic). Gap is too small for a dental pick, so the next option is some kind of solvent, as I only want to use heat as a last resort.
Re: Does anything dissolve silicone caulking?
Lee Schierer - McKean, PA
>Gasoline and silicone do not play well together. I can't say what it might do to your lens or any coatings that might be on it.
Lee
Terry in Edmonton
>Try using a feeler gauge or something similar. They are strong and come in very thin thicknesses. You might have to shape it with a pair of scissors to make it work. I would be afraid of a solvent damaging the lens coatings.
I'll try it...
John in NM
>Not too worried about the coating, the scope is old enough (1960's at a guess) that the coatings are probably mineral rather than polymer. Thanks!
I do have some shim stock...
John in NM
>That might do it, if it doesn't fold over instead of slicing. May give that a try if the gasoline fumes overwhelm me ;)
Re: I do have some shim stock...
Gary Evans---Tallassee, TN
>You may have to soak it for awhile before the silicone softens up. It won't be an immediate reaction.
Gary
The answer is no
Bill Tindall, E.TN
>This stuff is a cross linked silicone and nothing will dissolve it. However, given the right solvent something MAY soften and swell it making it weak enough that the lens can be forced out. If hot mineral spirits doesn't work probably nothing will. Heating the assembly may be a more successful approach. Polymers such as this one generally become less viscous when they are hot.
Something basic like lye will chemically attack this material but it will also attack the glass.
Jesper, Denmark
Re: "Basically" Agree.....
Jesper, Denmark
Dale Lenz
Re: Might try... *LINK*
Dale Lenz
>Silicone Be Gone. Let us know how it works.
Silicone remover?
Re: Might try...
Tony - Memphis
>Saw something similar at Lowe's recently. I plan on trying some when I recaulk our shower.
Tony
Jim Dillon
>John,
Agree with Bill on this one, but that product mentioned by Dale looks interesting. It contains kerosene, amphorous silica, and sulfuric acid, so handle with care (per DAP's directions) if you decide to use it. I'm not sure I would use it though around optics that might have sensitive surface coatings etc. Maybe a hair blow-dryer, coupled with a small "pick" might work??
Jim
ebd
ebd
>What about softening it in boiling water?
Re: Might try...
Fred Davis
>Tony ,
do yourself a favor and try PolySeamSeal for your caulking , you will be glad you did.
Tools like a dream with the tip of your little finger and cleans up with water and in addition, it is a powerful adhesive and you can paint it.
Silicone can't do any of the above.
FredD
I've used something similar...
John in NM
>As far as I know, such products are intended for siliconized acrylic caulking (and the stuff I used on mom's sink worked great BTW!).
After looking at the MSDS, the acidic components would worry me, as they are more likely to etch the lens coatings (usually MgF2 or something similar) than organic solvents.
But thanks!
