Slightly OT -Carbide burr on aluminum?
DouginDenver
>A carbide burr for non-ferrous metals has numerous spiral flutes as opposed to one for ferrous metals, which looks more like a prickly pear.
The short question is can I use the non-ferrous kind in a laminate trimmer? They can handle the rpms, so I can't see why not.
The longer question is what kind of control do you have over those things using them freehand? To me it's like using a router bit with no guide bearing freehand - which brings up images of the router bit taking huge gouges out of the work, and maybe me. But burrs are meant to be used freehand with die grinders, so it must not be bad. What I want to do is increase the I.D. of a ridge or ring inside an aluminum alloy casting. I want to remove maybe 3/16" all the way around. I was hoping to remove most with a burr then file to the final line. Doable or nuts?
Re: Slightly OT -Carbide burr on aluminum?
It sounds like it will work...
John in NM
>But it's going to sound horrible! Doesn't sound like you're taking off much material, I think you'll be ok if you go slow and make small passes. One shop I worked for used to rout alumninum as if it were wood - horrible job, but it works. Medium to heavy cuts you need a pattern and guide bearing like for cutting wood. Chips are super hot, so I used to wear a long sleeved shirt with rubber bands on the cuffs, long gloves and double eye and ear protection (and I'm that guy who always is forgetting to put on the safety glasses!), but I don't think you'll have that kind of chips since those burrs are much less aggressive than router bits.
GalenV in Iowa
>I worked in an aluminum and magnesium foundry many years ago as a casting finisher. (1966-1968)
I could bring a rough casting right down to a scribed line with a pnuematic hand held die grinder and rotary burr. The speed was about 25,000 rpm.
This was "soft" aluminum before heat treating! To make repairs after heat treating or welded spot is harder than "---L". Slower cutting and used a lot of bees wax on the burr for lubrication and fill the burr so you took less of a bite.
Suggest you find a piece to pratice on before you try cutting a critical part.
Formica use I have no idea.
Galen
Old Hill-McCanna worker, Place now Fansteel Wellman Dynamics
William Falberg
William Falberg
>I do it all the time but I'm nuts and it scares the ---- out of me every time. It IS fast however so worth my while. I use a two-fluted 5/16 carbide bit and brace both hands as close to the bit as possible to keep it from "catching". "Gentle but firm" takes on a new meaning. Very scary at first but you do get the hang of it eventually. Eye protection and watch where you stand and where the pieces are going to go when things go wrong. Like I say, it's crazy, but do-able. Saves a lot of filing.
DouginDenver
>Wait, you freehand aluminum with an actual router bit - not a burr?
Rick L
Rick L
>"A carbide burr for non-ferrous metals has numerous spiral flutes as opposed to one for ferrous metals, which looks more like a prickly pear."
Not true...the prickly ones are double cut and more aggressive. The others are single cut and less aggressive. There is no distinction between non-ferrous and ferrous in this description.
It's doable by all means. I do it often. Just hang on tight so it doesn't jump and grab. You can use the router like a die grinder without the base as well. Easily used on wood and plastics as well.
Rub some chalk on the handfile first...easier to clean the file that way as some soft aluminum clogs the file easy.
DouginDenver
>I was just going by the label on the vendor's case and what the guys at Tool King said. The ones in the "non-ferrous" case looked a bit like solid carbide upcut or downcut woodworking bits - spiraled, with sharp blade-like flutes. The ones in the ferrous case had lots of individual points. What they said made sense to me because the ones with tiny point would clog with aluminum, and the ones with spiraled flutes wouldn't bite well in steel. But you suggest I get the prickly kind for aluminum alloy and just use bees wax to keep the aluminum from sticking?
Rick L
Re: How did you misread my post...
Rick L
>so completely as to change all I said. Look at the burrs at www.mcmaster.com and read their descriptions and applications. I think your tool guys are all wet on burrs. Your so called pineapple are double cut and more aggressive and would probably grab on you. I have no idea of your skill level. High speed steel burrs would work on aluminum and are a lot cheaper.
I said CHALK on the handfile, not beeswax!
You are partly right
DouginDenver
>I did confuse your post with others on the beeswax. However, I've done cosiderable reading since I first posted, and there are indeed non-ferrous burrs. There are single cut and double cut as you describe, but also a variation of single cut with even larger flutes that is commonly called "aluminum cut."
William Falberg
William Falberg
>My bad. I was was talking about router bits for material removal. This is the exact tool:
http://i282.photobucket.com/albums/kk264/falbergsawco/Router6we22DS.jpg
Probably wrong but very fast and aggressive for AL.
