drum cases
drum cases
drum cases
paul delatorre
>looking to build drum cases, what wood? needs to be as lite as possible,
Re: drum cases
Re: drum cases
>This is just to hold the drums, right?
How about some 1/4" or 3/8" plywood? You could do it with bending plywood if you want a tight radius. Do the top and bottom of some 1/2" plywood and have several seam areas with 3/4" stock. If your radius isn't too tight, you may be able to use ordinary 1/4" plywood.
Re: drum cases
Clint Searl
Paulownia
Clint Searl
>Or white cedar.
Clint
