Removing Danish oil-
Dave in Haverford PA-
>Am refinishing a mahogany table and decided to finish with Tried and True Danish oil but I don't like the look. How do I remove the oil?
How long has it been on?
>If we are talking about a day or less, I'd wipe down with mineral spirits and see what happens.
no need to remove
Bill Tindall, E.TN
>There may be no need to remove depending on what you want to use next. Shellac and varnish will go over it and you will get some extra depth in appearance from the oil. A typical Reproduction finish is dye stain, oil and then shellac.
Re: no need to remove
>Thanks. You both solved my problem
