Colored epoxy string inlay
Barry Rubenstein
>Wonder if anyone has done any string inlays using colored epoxy instead of thin strips of wood. I seem to recall an article somewhere about this. My concern is that the epoxy might fall outside the intended location, how to apply it, etc.
Re: Colored epoxy string inlay
gary peterson
>I did this with a bookcase for a coworkers child. Really just some forster bit made holes of different sizes and filled with different colored expoxy to look like bubbles. This was the west system(I believe). With epoxy there are bubbles and settling you need to deal with. Make the inlay proud and it can be sanded down. Samples.
>Barry I do it all the time on turnings. Bleeding over the work is not a problem. You will plane, scrape or sand it down. Bleeding into the endgrain or torn grain can be a problem. Use thick epoxy or seal the area with shellac or lacquer will help with this.
Bubbles are the main problem. Plan on mixing more epoxy and filling some of them. I find that drilling into them to enlarge the hole helps. It's awfully hard not to get air trapped under the fill and then when you plane or sand that down you have another hole. Thin slow drying epoxies give the air more time to escape. You can also blow a flame across the top (not directly at it). The idea is to create an atmosphere starved of oxygen so the bubbles are attracted and pulled out. Works really well sometimes and not so good others.
You can mix epoxy into a clay like consistensy and force it in the groove. I haven't tried that exactly but have mixed some up and force it in large cracks. If mixed well enough you won't have bubbles.
