Using MDF as a cabinet door material
mamc
>I need some new shop cabinets to re-organize and re-claim the disaster that was once my basement woodworking shop.
I need them fast and hate the idea of buying them, so I was thinking of using maple melamine sheet goods and making MDF doors finshed with paint.
Can I use the MDF to make the stiles,rails and raised
panels?
I have not really worked with MDF for anything other then boxes and and shelves.
How does this material hold up under a router bit? Dusty I expect too.
Any Issues/Tips?
Re: Using MDF as a cabinet door material
MDF as a construction material
>In answer to your questions, MDF has a few important characteristics that affect its utility for various types of cabinet construction:
1. It's heavy. At 45#/cu.ft., MDF and coated MDF products (most of which are not readily available at retail), are very heavy. Depending on the sizes of the doors you plan to make, this could mean using more hinges.
2. It has little structural integrity, that is, stiffness. This makes it a bad bet for parts that need to be stiff such as stiles and rails. I'd recommend using it mainly for panels, where its dimensional stability is important. You can make the cabinets themselves out of MDF if you want, but they're going to be really heavy to schlep around.
3. It has lousy water resistance, with the exception of a handful of engineered boards that are moisture resistant. Even they are not totally resistant to water, so swelling of fibers in wet locations is likely.
4. It's a bear to paint. You need to seal the edges because they wick up paint. A sanded coat of B.I.N. or other sealer -- even yellow glue -- will provide a decent base for your paint.
>I have a friend who builds electronic console bodies out of MDF. He does a lot of routing and shaping according to particular templates. It is incredibly dusty and as I recall he does use carbide router bits as opposed to HSS.
He doesn't use the ordinary run of the mill MDF as I recall - it is a different variety which is stronger and has better binders. I would be uncomfortable using BORG MDF as something for rails and stiles. I'd be afraid of it bending and breaking.
Anyway - why not use an inexpensive wood instead? Poplar and soft maple come to mind.
Clint Searl
Clint Searl
>I made our master bath vanity doors and drawer faces from MDF. All are full overlay and the doors swing on European style hinges. Painted with Benjamin Moore alkyd High Gloss Impervo they are practically impervious to moisture and have operated perfectly for ten years. Did the same thing in a vacation home. Also made a router table of MDF. With the European hinges there's no problem of screws pulling out.
Clint
gary peterson
>time and money...easier and cheaper to buy or make?
Yes...
Howard In Toronto
>and no....
I've made living room cabinets entirely out of MDF
(the doors are frame and panel affairs and zero problems)
I've made book cases for my two boys, Genghis and Attila
(two are eight feet long with an uninterrupted shelf span and no vertical centre support)
You just need to know how to engineer for MDF
You'll never never never experience sag - in ANY direction
I've made shop furniture galore out of MDF
And that's in an unheated, un-air-conditioned garage shop in Toronto where the humidity some summers can approach 80%
So.....
here's what you do.....
- seal EVERY surface with paint or lacquer
- use simple housed joints like dadoes and grooves, nuttin fancy like sliding dovetails
- use the correct number of hinges
- if it's going to be a high-usage cabinet use thru-bolts and nuts on the hinges rather than screws
BUT DO NOT POUR WATER ON - OR SUBMERGE - YOUR CABINETS
because
yes it's true
MDF reacts badly to moisture
so don't make them wet
conversely
wipe up any fluids promptly if you do
I say this somewhat tongue-in-cheek because I use milk paint on almost all my MDF furniture which is just about 100% WATER and no problems
I'm a big fan
The pluses of MDF outweigh the dust and weight and screw holding abilities because it's CHEAP and FLAT and UNIFORM
And if you change your usage patterns and can't repurpose the cabinet, it's cheap enough to throw out
My 2C
HTH
Howard
Clint Searl
Huh?
Clint Searl
Ed O'Neill
>Today I finished building a built in for a friend. The entire build is made from MDF. I started using MDF for built ins when the price of plywood, veneers and lumber went so totally out of control. I've made frame doors with raised panels, doors with glass inserts and solid doors. In my shop I built cabinets using 3/4 ply with stiles, rails and doors of MDF. Living in the south with high humidity in an unheated , non-ac environment hasn't affected them at all. The downside as stated by everyone is the dust and the weight. I have the panels rough cut at the borg, keep a handtruck handy and double prime before painting. One thing I do to control the mess is to keep the shop vac handy and stop often to clean. Ed
A Wright
>I recently made shop cabinets, and used birch plywood with iron veneer around the edges for the doors and drawer fronts. I am happy with the results. I didn't want to spend the time making raised panel doors, and this was quicker and easier.
As far as MDF cabinet doors, I have used it for the center panel of paint grade doors. I used poplar rails and stiles with MDF panels, and they held up well. The MDF really cut down on the board ft of solid wood required, and it also saved the time of gluing up solid wood for panels (less time with the jointer, planer, etc.)
Ellis is correct that you need to seal the edges. What I have done in the apst is to use watered down drywall compound . I make it into a paste, spread it over the profile, and then sand/reroute it to shape once it is dry.
Thanks Y'all, appreciate the experiences
mamc
