Installing Prefinished Hardwood Stair Treads...
Brian McKearney
>I usually hang out on the Turning side, but thought that I'd ask this question here - hoping someone can clear up my confusion.
I've done quite a bit of woodworking - both turning and plenty of furniture projects, so I think that I can handle installing stair treads.
I've done a bit of research on the topic and I would prefer to purchase and install prefinished hardwood stair treads on my stairway for simplicity after the installation is complete - finishing isn't going to be trivial with the family around.
I'm pretty confused how folks actually install prefinished stair treads. From everything that I've read, it sounds like the most recommended approach is to glue the treads down, AND secure each tread with screws. Here's my confusion - if I screw a prefinished tread, then I have a screw hole that has to be filled and finished and this sounds like a real pain on a prefinished piece of wood.
Anyone have any experience that they can share? Do folks recommend just gluing and no screws? What about squeaks with no screws? Am I missing something, or is it the best approach to just install unfinished treads and work through the finishing later?
Any advice? Any good links that I should check out before I start this project?
Brian
