Finish Inside of Blanket Chest?
Ron in Sterling, CT
>I have just completed a blanket chest for my grand daughter made out of eastern white pine. I am in the process of finishing the outside of the chest. I have looked at a lot of old blanket chests and typically they don't have any finish on the inside. I know I don't want to put any kind of oil finish on the inside because of the lingering (like forever)odor, even though I see some woodworking mags are currently recommending it. I am wondering if it would be okay to put a coat of thin cut shellac on it. What is the advice and/or recommendation of this learned group? I am also going to post this on the hand tool side.
Ron
Re: Finish Inside of Blanket Chest?
One good choice
Bill Tindall, E.TN
>Put on a coat or two of thinned shellac. I usually do a first coat of 1 pound, sand smooth and then a second coat of one pound. Winds up looking like unfinished wood but it feels better and the wood won't sop up anything that might get spilled in it.Also the wood stays brighter than if it was left unfinished.
Post a picture of it.
Clint Searl
Clint Searl
>Waterborne poly is easy, fast, tough, and no odor. I prefer Varathane gloss floor finish for box and drawer interiors.
Clint
Dan Donaldson
>This shellac would be fine, but not necessary. I would put none.
Fred Davis
>Like Bill , wouldn't hesitate a thin coating of Shellac for a easy to repair, unnoticeable finish that keeps the wood clean and new looking .
FredD
I've Used Both Shellac and Water-based poly
>Good Morning Ron,
Both work well. I prefer the water based poly: one coat scuff sanded and tacked.
George
Most any finish :
Pete in Holland, MI
>Apply it. Let it COMPLETELY cure with the lid open for upwards of a month. Will be tough to smell anything after that. If that wasn't the case, you wouldn't be able to stand walking into your house with all of its finishes !
Michael Wilkins
>Use a thin coat of clear Shellac on the inside. If you have an aromatic cedar bottom or other fine-smelling softwood, don't put anything on it; it will mask the smell. Shellac dries fast and does not leave a lingering odor, even after being in a closed environment.
gary peterson
>Fred said it well, anything you chose as it will keep the inside clean. Thats a good idea.
