THE WOODRAT IS BACK!
Need your expertise on drawer mounts
Joanne in Pt. Pleasant, PA
>Getting ready to start cutting parts for a big built-in. The file drawers that will go in the bottom units are big and wide and I have super-duper full extension heavy duty Accuride slides. The sheet for these says side space is 1/2" + 1/32", 0.0. What does that mean? Do I have to allow 1/2" or 17/32" clearance between the drawer side and the inside wall of the cabinet?
Thanks in advance.
Re: Need your expertise on drawer mounts
>I don't have the sheet, but I think if you look closely it Says 1/2", +1/32". -0.0". In other words, the space can be up to 1/32" over a half, but it must be at least 1/2". The drawer won't fit if you allow less than a half inch on each side.
Tolerances
>This is fairly standard tolerance notation, Joanne, as Barry has pointed out. Your clearance must be between 1/2" and 17/32" for the slides to fit properly. In my experience, anything less than 1/2" is really too tight, but you can probably get away with clearance greater than 17/32". In the worst case, you can shim the slides with a slip of veneer if need be. Best to be as accurate as possible though.
Cheers,
I'm very tolerant!
>Or is that 'tolerable'? At least I hope I am. :-)
Thanks to you both. Sort of what I figured. Guess I'll leave a hair more than 1/2". The false fronts will overlap the drawers all the way around, so I can cover the gap to the sides, whether it's 1/2" or 17/32".
I have Zero Tolerance for Zero Tolerance
>anytime anyone mentions a Zero Tolerance policy, I start to bristle.
I did not 'plain that very well. Ellis is right, better the space is a little too wide and you shim to fit. OTOH, some of the slides come with 3/8" or shorter screws and you can't do a lot of shimming. For heavy drawers I often switch to longer screws. I bought consumer slides at the blue borg for about $12 and they came with screws. Bought some a a wholesale place that sells to cabinet makers for about $4 and had to provide my own screws. Still a good deal though.
I often make a filler strip that mounts inside the cabinet on each side to mount the drawers to. I leave them too thick and don't install them. After I make the drawers, I make a 1" spacer. I Check the drawer in the cabinet with the filler and then saw or plane the mounting strips to fit.
Clint Searl
Consider making the drawers first
Clint Searl
>I rather fit the box to duplicated drawers than vice versa.
Clint
Fred Davis
>Joanne, \in addition to maintaining a 1/2" plus space on either side of the drawer, it equally important to keep the cabinet opening sides parallel front back and the same dimension top to bottom.
For instance you can get drawer openings at the front right fairly easy and if the opening opens or worse, closes at the back , then you have a problem you want to avoid.
FredD
Re: Consider making the drawers first
>Thanks, Clint. Drawer boxes ARE made--I bought pre-made boxes. They are beautiful and machine-dovetailed and probably cheaper than I could have made them. Since they are for legal-size file drawers, I didn't want to mess around.
Been there done that. Got the T-shirt.
Victor Parisian
