Help
Help
Help
Lewis Dodd
>I have an old wooden baby high chair that has been through at least 4 generations. It has some dark stains on the tray, What recomendations are out there to try and remove them. Some kind of bleach? The wood is pretty light and varnished, not sure what the wood is, but I sure would like to get these out or reduced before I re finish the tray?
I thought of "tire bleach".
Lewis
Re: Help
Wood bleach. *LINK*
>Of which there are several varieties. You may want to try and find a 2 part wood bleach. Read the article.
Wood Bleach Article.
Re: Help
Clint Searl
Re: Help
Clint Searl
>Assuming you've stripped it to bare wood, try a strong solution of swimming pool/spa shock treatment composed of calcium hypochlorite.
Clint
Re: Help
Hold on here........
Bill Tindall, E.TN
>It is best to know what the chemicals are before doing chemistry with them. If the stain is from mold then a chlorine bleach will bleach the mold stain colorless, and Chlorox is as good a choice as anything. However, the chlorine bleaches are strongly basic and a strong base will darken oak.
If the black stain is from iron the chlorine bleach will make it worse. For iron you need oxalate or citrate to remove the stain. Not sure what else in the universe would make oak black. But the bottom line is don't pour chemicals on this piece until you do some testing with them in a small area.
Personally, I would not do anything but clean it up with steel wool and some wax. You run the risk of making it look worse.
