help with Jessum master slide
McKay
>I have a master slide that I like very much except that the way the fence works is from the back side as shown in this first post. The second post shows the way most slider should work. ie. from the back so that large sheets slide in from the front of the saw. Altendorf, SCMI and others work this way, but I am unable to figure out how to make this system work with the way the fence is made. Any help would be appreciated.
Re: help with Jessum master slide
second pic
McKay
>Here is the way that I would like the fence to be situated.
Re: help with Jessum master slide *LINK*
Andy Lincoln,in Dearborn MI
>McKay,
Here is an article/review in the WoodCentral Articles section that shows the installation and set-up of a Jessem Mast-r-slide.By moving the fence and its attachment posts you can set the fence in multiple configurations.
Andy
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=reviews&file=articles_730.shtml
Michael Wilkins
>I don't have this type of sliding carriage like yours; I can only speak from my experiences with a Laguna sliding table saw, the one with the true format-style sliding machanism with the sliding table next to the blade. I use the fence in the end closest to the infeed side of the slider(as you are facing the machine) for cutting solid wood or narrow pieces. Generally you would use the fence at the far end (like your 2nd photo) for cutting sheet goods, plywood, etc. I have used mine in several locations, as the fence can be located anywhere along the length of the slider. I don't there is a hard and fast rule as to where you should mount your fence. Whatever works for your and your situation should be the deciding factor.
Stay safe and watch those fingers.
