Re: Ceramic Bandsaw Thrust Bearings
Jim DeLaney, Austintown, Ohio
>Just curious
How could a brief sparking on the back edge destroy a blade? If the blade is set up right, it'll only contact the ceramic when a lot of pressure - like from too fast an attempted feed speed - is applied to the front (teeth) of the blade.
How did you blades break? At the weld? After how long a use?
Could they have been re-welded and put back in service?
It's hard to believe that a 180" blade band gets hot enough to affect the steel's temper. It's a spot heat, which will then have a whole revolution of cooling before seeing the ceramic again. Did the hot blade melt the tires? It'd be contacting the tires for a lot longer than it's be touching the ceramic.
If you mean the ceramic side guides, then they were likely adjusted too tight.
I've run an awful lot of wood through my Laguna - with no blade life problems at all.
Jim D.
