Water Heater pop-offs OT
Randy Johnson Connersville IN
>I encountered a problem today that is going to cost one of my company�s customers a lot of money, and since it�s possible some of you here might have a similar setup I want to pass it along.
My main job responsibility is reading gas meters. Part of the job is finding out why usages on individual meters are significantly higher or lower than normal for any given month. Today, one meter showed a usage that was a little over four times what it should have been. The homeowner invited me to check things out and I found a pop-off valve on the water heater stuck in the open position. He was not aware of it because a hose was attached to the tube coming out of the valve. In turn, the hose was stuck inside a 1 � drain pipe. The water heater had been draining unnoticed for who knows how long, all the while running the burner almost if not constantly. This particular customer�s problem was compounded by having an almost unheard of 100 gallon water heater. (More gas being used while the burner is on.) Just the cost of his gas this month before all the little add-ons like service charges and taxes is going to be a little over $330. His water bill will also be higher.
If any of you have a setup like I have described, or have the relief tube stuck through the floor into a crawl space, CHANGE IT! The end of the relief tube should be easily visible so you will know if the pop-off has stuck open.
We find this problem more often than you might think.
