Glue for teak
Glue for teak
Glue for teak
>My old pal Pimo is working on a major teak lamination and would like to know if there is anything superior to epoxy for teak. We used to use West System epoxy for exterior teak work and we had no problems with adhesion. This is an interior job, but the glue lines will be exposed, so he doesn't want the creep of PVA nor the dark lines of resourcinol.
Any other suggestions on either glue or technique?
Re: Glue for teak
I've used plastic resin glue...
John in NM
>Seemed to do fine and the color blended in ok. This was a bent lamination too. Whether its actually better or worse than epoxy is beyond me, West System is good stuff.
Re: Glue for teak
Re: Glue for teak
HCS
>Hi Ellis,
I've got T-III going strong -outside- for 3 years without a problem! Yes, it is teak and low tension bent lamination.
Chico
Re: Glue for teak
Re: Glue for teak
Thomas S Stockton
>I would use gorilla glue, it is what it was originally designed for and actually one of the few times I would recommend it.
Tom
