200+ woodworking book reviews
Cupping Table Leaf
Cupping Table Leaf
Cupping Table Leaf
J. Rose
>Back in August I visited a friend in VA to build a entertainment center and dinning room table, in 3 days! We got most of it complete and my friend has been finishing them ever since. He completed the 6' x 7' entertainment center and is using it, and now he has been working on putting poly on the table. One of the 2.5' x 4' leaves has cupped about 3/16" To make this leaf we glued 4 red oak board together clamped them and put a few pocket hole screws in the bottom, after about 20 minutes we unclamped them and set them aside. He has put 2 coats of poly on both sides of the table leaf so far. Any suggestions on how to get the cupping out? He is convinced to take it into a sauna for a few hours, then putting weights on it as it cools and dries. I say cutting one of the seams and squaring it on the table saw.
TIA
Jeff in Iowa.
Re: Cupping Table Leaf
>How about setting it outside in the sun on a warmish day for a couple of hours or so? Set it with the bottom facing towards the sun.
See if that does the trick before you do anything harsher.
>If he decides to rip it, be SURE to remove those pocket hole screws. Those things are hardened and will ruin a saw blade in less than a second.
Is the leaf to be clamped/screwed to a frame? Might be able to pull it flat.
gary peterson
>Once, I put a finished blanket chest lip into my small humid bathroom to correct a warp. I left the chest in my van during a hot day for 13hours while I worked and discovered it when I got there. Must of dried it some more. Anywho, after a few days the top went back to normal, I delivered it after one more coat of finish, and haven't heard a word-i see the owner frequently.
Would seem you have a moisture prob. Either make a new one or as suggest rip and redo...but the wood is moving and that needs to be taken care of first.
Howard Acheson
>What was the purpose of the pocket screws?
Is the warp across each individual boards in the whole leaf or is just one of the boards in the leaf warped?
How and where was the leaf stored before finishing?
JMOHNIKE@PSNW.COM
>If it were me, I would put it in the room where it is going to live for 3-4 weeks and let it stabelize. Then correct the problem as necessary.
Joe
mamc
>Our formal dining room table is solid cherry (store bought wedding gift pre woodworking) and as with most other similar tables I ahve seen the leaf's all have cleats laid cross grain on edge on the bottom of the leaf. These cleats are screwed into the leaf with an expanded hole to allow for movement. Performs the same flattening function as a breadboard edge and you can't see it when inserted into the table.
Live with it
Ed Mulligan, Cape Cod MA
>Jeff,
A 30" wide panel made of flatsawn wood is going to move unless you maintain constant humidity or add cleats as another poster suggests. 3/16" isn't a lot, all things considered. If you do correct the cup, it will return.
If you make another table with a free leaf, use quartersawn wood. It will be the most stable natural material. Or, use mdf or particle board with veneer. Another possibility: alternate the growth ring orientation in the panel. Then as the boards cup and uncup you will get a wavy surface instead of a big cup.
Jeff in Iowa.
>Thank you for your responses. We used pocket holes since I brought a limited number of clamps with me and we needed them for other parts of assembly. We tried to align the grain so that it was as close to quartersawn as possible to prevent warping. I think what happened is he didn't get both sides of the wood sealed up well at the same time, causing the wood movement. He is going to try a couple of the suggestions. Thank you.
Jeff in Iowa.
