WD-40 on plywood, what to do now?
Jeff
>I am building a desk and when clamping part of it somehow I hit the can of WD-40 sitting near by and sprayed it on the side of the desk. I wiped it down with mineral sprits as soon as it happened, is there anything else I would need or should do so the stain takes right?
Jeff
Re: WD-40 on plywood, what to do now?
What kind of stain?
>I don't know and am speculating like mad here, but, if it's an oil stain, you're probably OK.
I suggest you experiment - take a piece of scrap, tape half of one face off, try to reproduce the amount of WD40 you oversprayed on the other half, remove tape, stain whole surface.
Who knows? Maybe it'll turn out to be a great stain controller, and you'll have found another use for WD40.
Re: What kind of stain?
Jeff
>It is an oil based stain. I should have thought of reproducing the over spray. I will try that and see what happens.
gary peterson
>mineral spirits has oil in it, try the naptha(sp?). goodluck
Good news... you get to name the color!!!
Frank on Chestnut Hil
JMOHNIKE@PSNW.COM
>I do not think the stain will be the problem, the final finish will be the challenge. I would consider anti fisheye in the final finish you can get it at any auto paint supply store. Put in the sanding sealer and clear coat. If this is the type of finish you are going to apply.
Joe
No problem.
slashdev
>There is no silicone in WD-40, so the finishes will be fine. Some ingredients of WD-40 are fairly volatile, so they have probably already flashed off. In my experience, the rest will evaporate a little more slowly, maybe a week. I usually let oil-based stains dry for a couple of days anyway.
Good Luck!
