light-colored, machinable wood to go w Cherry-----
ronster15------WebKitFormBoundaryYukplFdFRMs+31yy
>I need to select a light-colored wood for the 3 inside sides of a bunch of drawers. Drawer fronts will be cherry, which I already have stockpiled. Bottoms will be baltic birch. I had originally planned on poplar sides, though the green hues sometimes bother me, because it's cheap and easy to work with.
I now see that "soft maple" can be had for not much more $. But I have no experience with it.
I'm doing machine cut dovetails on a basic (porter cable) 12 inch jig. About 20 drawers so I need to buy a bunch of whatever I go with.
Will this soft maple have worse tear out than poplar? Will it's color be more complementary?
thanks,
ron
Re: light-colored, machinable wood to go w Cherry-----
Go with the soft maple. You'll like it
Tom Rex in TX
Agree. Could Also Use Birch
Dave Bair, Eaton Rapids, MI
>It would be a good use for that sapwood I always seem to have plenty of whenever I buy a bundle of cherry.
Bart Goldberg
Another idea - Sapele!
Bart Goldberg
Re: Go with the soft maple. You'll like it
AZ, Colorado Springs
>Go with the maple
Jesse Cloud
>Maple and cherry is a classic combination. I use it a lot.
Maple might tear out a little more than poplar, which is just about the easiest wood to work there is. Can you use a backer board on your dovetail jig (shift it or replace it often)? Also, try to avoid lots of figure where you will be cutting the dovetails. Look for nice straight grain at the lumberyard. Also, don't leave 1/2 maple stock around too long, it will want to warp. I suggest milling it close to when you will be cutting the joinery. Once the joinery is cut, go ahead and assemble your drawers, don't leave it sitting around - the drawers will come together much easier!
green poplar is fleeting
Bill Tindall, E.TN
>10 min in the sun and the green is gone for ever and replaced by brown. The same will happen in the drawer, just slower.
But, soft maple is a very nice wood, just more expensive.
Thanks all -- I'll try the maple!
ronster15
