Load limit for kitchen floor
Bill H - Evansville, IN
>I am getting ready to install an island in my kitchen and the weight occurred to me when I tried to pick up the granite top. The island is a 3'x2' cabinet that has feet instead of being a traditional cabinet. It will hold pots and pans and is already pretty heavy w/ just the drawers (no counter top or contents). The floor is 2x10 joists, 16" on centers, w/ 3/4" plywood + 1/2" waferboard subfloor. Did I screw up? Does anybody know how much weight I can put on the floor? This seems like a lot of weight in a small area, especially focused on four feet.
Thanks in advance,
Bill
Re: Load limit for kitchen floor
GalenV in Iowa
>Your floor is probably designed for an "average" 40 lbs per square foot live load.
Depending on your floor joist direction and span will make a big difference. Your flooring will distribute your four legs out over more than just a point load. I'd say one leg in mid span of 16" spaced joist will load two not one.
I use the term average as the same joist may span a greater distance in say in the living room compared to the kitchen.
Your frig full of food is one heavy load but it is often on the wall perimeter and therefore close to the end support for the floor joist.
Probably not a problem unless you have another heavy load on the same set of joist.
Sure hard to tell from here not knowing the island weight and location and span of joist.
If you're really worried and the joist are open in the basement, double them up in that area.
Galen
engineer's information
Bill Tindall, E.TN
>I had some engineering work done when we were designing our house. The floors were designed to hold 50 pounds/sqft. I presumed that this value was some standard. A loaded freezer, or a very fat visitor, is going to put vastly more stress on a floor section than this counter top.
BTW A design limit of 50 #/sqft does not necessarily make for a stiff floor. To that end we over-engineered it.
>I agree with the guys above.
To know for sure, an Engineer would need more information. The span would be a very important factor. The species of lumber and the grade also.
Form my experience building 2X10's will span about 15'. That's assuming No 2 yellow pine. Spruce is not nearly as stiff. Neither are lesser grades.
The load per SF is also important. I think locally they use 10 pounds per SF dead load and 40 live load. The fact is that the fridge is too heavy, but as mentioned, they are usually near a wall and the bearing of the joists.
The answer is to try it and see. The floor won't collapse unless you have really screwed up and cut the joists below or given the termites a go at it for about ten years. If the floor is shaky when people walk by, you may have to stiffen the floor or put a beam under it. A hard tile floor would suffer is the floor is shaky.
It's not that heavy!
Bill Tindall, E.TN
>While the top may seem heavy, by my calculation it is only 17 pounds per square ft, way less than the design limit of the floor. Think of the load of a full bath tub or a freezer full of stuff. Don't sweat it.
William A. Roland
William A. Roland
>I have a 4'x6' Granite covered island in the middle of my kitchen. It has a lot of pots and pans plus a JENN-AIR glass top stove and recycle bins. It has not been a problen for over 5 years.
>Thanks for all the responses and reassurance. I just started to sweat a little when I tried to pick up the granite top and pictured my island sitting in the basement with my wife standing next to it shaking her head.
Thanks,
Bill
>Bill, we have too many Bills here. Two Bills and a William.
Bill commented that the floor is designed to carry 40 pounds per SF and the granite only weighs 17 so it should be fine. Actually the floor is designed to carry 10 PSF Dead Load and 40 PSF live load. Live load is stuff like people walking around and things that won't be left in place long term. The structure of the floor itself already accounts for the the 10 pounds. The cabinet and top would be additional.
I still think the floor will be fine. You will know when you put it in place. Set it where you want it and stand beside it and have someone walk around the area. Gently rest your hands on it and see if you feel the top move. If there is a "scary" (highly scientific term)amount of movement you may need to reinforce the floor. Unless the joists are already cut or rotted, or termite eaten there is a lot of room for error here. It will sag badly if it is seriously over loaded and still not break. Then imagine what it will be like when forty of your best friends show up for the house warming.
