Blade for resawing
Blade for resawing
Blade for resawing
mdclor
>I have a 14" Jet band saw with 6" riser. I need to resaw some QSWO that is 6 to 7.5" by 7/8" to make 1/4 inch panels. I have 1/2 and 3/4 inch 4 tpi Timberwolf blades. Would anyone recommend one over the other? Would a different blade be preferable? Due to my very limited supply of stock a second chance is not an option.
TIA,
Merle
Re: Blade for resawing
Fred Davis
>Timberwolf blades are good quaility blades and I would opt for the wider blade if you saw can tension it enough.
Either one will do the job ,but resawing goes for wider blades then that typically run for curve cutting.
FredD
Hank Knight
>Highland Woodworking in Atlanta sells a resaw blade called the "Wood Slicer." It has a thin kerf and leaves a nice surface. They come in 1/2" and 3/4" widths and are not teribly expensive compared to "high end" resaw blades. I've found the 1/2" one to be an excellent resaw blade. I recently bought a 3/4" one but I haven't used it, so I can't compare it to the 1/2" one. If I were faced with a resaw project like yours with little margin for error, I'd buy a new Wood Slicer for the job. I have always gotten fast shipment from Highland Woodworking, but I read several months ago that they had some delays shipping the Wood Slicer blades. I don't know what that was about. I'd give them a call and see if they have your length in stock and if they could ship it right away.
I have no affiliation with Highland Woodworking or Wood Slicer blades. I'm just a satisfied customer.
Hank
>I have a love/hate relationship with my bandsaw. (A 14" Delta with a riser) When I get it tuned up and cutting as expected, I love it, the rest of the time, not so much.
I have not used a blade wider than a 1/2" but a 1/2" 3 tpi blade has worked well for me.
If I had to get three pieces out of 7/8" stock I would put a fresh blade on the saw and tweak it as best I could and go for it.
If I could afford to get two pieces out of each piece, I would do it on the table saw. With a good blade (Forrest War) I would rip it from each edge and then clean it up. I might let it acclimate for a few days after I ripped it to see if it warped and then use the extra thickness to flatten it. Before I owned a band saw this was what I always did and it is reliable. No Blade drift, Barrelling, etc. The kerf is an 1/8" but the clean up is minimal. By the time I clean up both faces of the band saw cut, I have not saved much.
OTOH, I have repeatedly cut veneer with the bandsaw when it was feeling good.
Jim Dillon
>Merle,
I have 15 year old Delta 14 incher with riser. Somewhere I seem to recall reading that a 1/2 inch wide blade is about the maximum width that one can use on this class of bandsaw and still get adequate tension. Although I now use the 1/2 inch Lenox carbide blade for resawing, I have used both the 1/2 inch Timberwolf and Woodslicer and I think you would be happy with either. I also installed an aftermarket tension spring several years ago and I think that really helped achieve good tension. I think some of the newer bandsaws come with better tension springs, but I haven't kept up with the latest and greatest. Feed the wood relatively slowly and you should do fine.
Jim
mdclor
>Thanks for the input. I ordered a 1/2 inch Woodslicer from Highland because I thought the oak might dull my Timberwolf too quickly and I am not certain about getting the proper tension for a 3/4 inch blade. I greatly appreciate the quick responses.
Merle
>Good Afternoon Merle,
My bandsaw is identical to your own, and I have been very satisfied with Timberwolf blades. I have just used the 1/2" Wood Slicer for the first time to split 8" wide QS sycamore. I was delighted at the wood slicer's performance. I got more drift than expected, but the sliced surfaces were surprisingly smooth and required minimal planing: one or two passes thru my DeWalt 12 1/2 incher. The blade sliced like butter. I was very careful to properly tune the saw and align the resaw fence. I think you did the right thing.
George
Me too
Tony - Memphis
>I have a Jet 14" w/riser and I have been using the Highland blade for a while. I'm always impressed with how well it cuts. That's why I ordered a new one when I got the riser kit. I haven't tried any other resaw blades, so I can't comment, but I have been happy with the Timberwolf blades I have used.
Tony
mdclor
>George, thank you for the validation!
Merle
Re: Blade for resawing-Update
mdclor
>I just used the woodslicer from Highland today. It did a great job and I am very happy with the results. It went through 7.5 inch oak without any difficulty. There was very little, if any, drift with the blade either so I didn't even need a resaw jig. Thanks to all for the suggestions.
Merle
