New brand of Cyanoacrylate glue *LINK*
Dale Lenz
Dale Lenz
>Like many here, I've been using cyanoacrylate glue to fix/fill minor defeats in my wood. Been purchasing from hobby stores that has their name on the label, IE John's Hobby House. If you read the fine print may of came from A.O. Smith in CA? Problems: Cap stick onto the spout after a while and the application tip plugs-up, Plus, when my glue gets about 2/3 used, it starts to go bad, gets thick.
About six months ago, found another brand of cyanoacrylate glue: Mercury Adhesives. Due to Mercury's inner/outer cap design, the application tip does not plugged-up and I'm on my second bottle and seems to stay fresh, does not thicken up within my time frame. Still have problem with the outer cap getting glued on to the application tip, time for an acetone bath at that point.
Over-all I'm very please with Mercury Adhesive cyanoacrylate glues, not sure, may cost slightly more than the hobby store brands. Link below tells their story
Mercury Adhesives
Re: New brand of Cyanoacrylate glue *LINK*
A Wright
>I have had the same problem, and recently found out that you can buy a two pack of replacement caps to fit CA glue bottles for $2.50 at Woodcraft. I bought a pack because a $1.25 replacement cap is better than throwing away half of a $10 bottle of glue
http://www.woodcraft.com/Product/2000346/1503/Replacement-Adhesive-Nozzle-and-Caps--2-pieces.aspx
comments on their web site
Bill Tindall, E.TN
>Under their "science" section they describe the advantages of making the product in the US and how this location results in improved stability. This claim is well justified. The discussion on distillation is baloney. Overall, I thought they made a good case for the quality of their product compared to foreign made material in spite of the bogus distillation discussion.
Loctite once made this stuff in the US. If they still do then it should be as good or better than this product. Originally it was invented and made at Eastman Chemical, Kingsport, TN.
The trick with Mercury CA...
David Barnett - SW FL Gulf Coast
>...is to wipe off the bottle tip before reinserting the cap, especially when using the medium or thick viscosities for extended sessions where you might be slower to replace it. It also helps to chip off any hardened buildup that may have formed. Of course, if you replace the cap immediately after applying glue it's unlikely to stick shut, but this isn't practical when you're filling voids and so on. One thing, though... if the cement gets on the bottle's threads, it'll act like other CAs and stick until you break it free.
I love the M1100G for void filling, whether I'm using wood, metal or stone dusts. I'm doing these veneer core plywood glue-ups where the edges (not the faces) are the major design element. Sequential strips yield patterns of 1/4-inch long sequential voids which I treat as micro-decorative opportunities. While the other two gap filling CAs are fine, the M1100G scrapes crisply and cleanly. I use it clear, too, with no issues but Mercury makes a special non-blooming gap-filler, though I've never tried it.
BTW, the thicker M3500FL is superb for temporary fixturing. It's more shock resistant than any CA I've ever tried, nice when you're turning small work. I also use it to 'dop' (fixture) heat-sensitive gems while I'm carving them - much cooler than hot pitch or molten shellac.
Mercury CAs are the best I've ever found. Because of their purity, a big issue in CAs, they also seem to have a better open shelf life than others, too.
