OT old propane tank
OT old propane tank
OT old propane tank
Jerry Gibbs
>Any thoughts on what to do with a 20lb propane tank that the dealer won't fill, the garbage man won't take and neither will the local recycling center. Thought about making a portable air tank, but not sure how to safely purge the tank. Jerry Gibbs
Re: OT old propane tank
Craig in Silverdale
>Some propane dealers and RV stores around the Puget sound area will allow you to drop off your tank. Don't know what they do with them. Not sure where you live, but you may want to call around. To purge the tank, I would think that once you remove the valve it would self purge. Just don't make any sparks while removing it. Otherwise it could ruin your whole day.
Ron Bauman
>I can't say I've ever done this, but at one point I was going to buy a used tank (500 gals) from a scrap yard and they told me the only way they could cut it up to my specs was to fill it with water to purge it. The time and money involved were more than I cared to pay at that point. I'm not sure this is the safest way , just a bit of info I picked up on the way here.
Mark Brennan
>If you need a new tank, take to Lowes and trade for a new full tank, about $17.
William Wilkinson
>I suppose drilling a hole in it to empty it completely with a powered drill might be one of those things you want to record and put on youtube. Wear the asbestos suit.
That aside, a hand drill might do it. turned slowly, it would not generate heat or sparks.
Once it is empty, they would make a great salad bowl if it is cut in half!
Seriously, I am surprised that a retailer that sells tanks will not take them back. The ones in our area do that.
John E in SC
>I would try the "trade in" thing at whatever nearby big box store or convenience store offers it. If they won't take it, my next thought would be large caliber bullet from long distance in the back yard (but may not be a good idea depending on your neighborhood!) Once "purged", you might even have to cut it up to dispose of it as scrap. I would probably NOT try to make an air tank out of an old propane tank. If the tank is old, I'd be worried about pressurizing it too many times, or it might rupture. (And commercial air tanks are actually pretty cheap if you need one.)
A few times my wife has bought disposable helium tanks from Wally World for balloons at kiddie birthday parties, and those things were a PAIN to dispose off. Trash collector wouldn't pick up any kind of tank, even though it was helium and not flammable. Had to end up punching holes in it for them to consider it "safe" enough to take.
Lee Schierer - McKean, PA
>Remove the valve on top and stick an air hose inside to purge it. They use a locking thread sealant on the valve threads so you'll need a good grip on the tank and a large wrench to get the valve out.
Lee
Purging Fuel Tank
>Should not be done with air. Rather, use water with detergent added to both displace any gas and remove any residue on the walls or bottom of the tank.
Propane tanks are low pressure vessels; not suitable for high pressure air. Garbage guys will usually take'em if the valve is removed, but contact your county solid waste agency office as they may have a local collection point where you can drop it off.
Lewis Dodd
>Geez, Christmas is coming, put a bow on it, at least a sign that says free and put it on the curb. During floods, we used to use them for target practice as they floated by down the river!
Lewis
John E in SC
>Like the sign idea, but instead of "free", put "for sale $10" on it. Had a friend put an old sofa out by the curb with a "free" sign on it. Nobody touched it. He put a "for sale" sign on it, and it was gone within a half hour! (stolen - not paid for.) Apparently if it doesn't appear to be worth something, nobody wants it!
Thomas S Stockton
>I did what others said and took it to the local Home depot and exchanged it for a new one.
Tom
Dan Donaldson
>If it is over a certain age, they won't take it.
In El Paso . . .
steve mackay
>anything I want rid of, put on the curb and put "free" on never moves. Put "$10" on it and it'll be gone by morning ! And I MEAN anything ! It'll be in someone's yard sale on saturday.
Purge and air tank use
Tom Dunlap
>If there is still gas, use it up, get a big passle of meat and BBQ till you empty the tank. Then, open the valve, would it be necessary to say...outside in a well-ventilated area?...I guess not, WC folks are smarter than that :) Take off the valve and let it sit in the sun to vaporize what ever might be left. Soapy water and rinse...sun dry.
Years ago I bought a conversion kit with a pressure relief valve, pressure gauge, Shraeder valve for filling and a hose from Harbor Freight for about $12. The tank worked well.
It's hard to imagine that they aren't made to take 100# of pressure. May be though. Check the stamped label I'll bet there is a rating. There is likely at least a 5:1 safety factor too. Otherwise more people would be blowing themselves up. Ever looked at spud guns??? Those folks use propane tanks for air storage...not that they always have all of their neurons in prime shape though.
Re: Purging Fuel Tank
GalenV in Iowa
>Mark
You said "Propane tanks are low pressure vessels; not suitable for high pressure air."
I think you will find the tank is probably ASME rated 250 psig at 125F.
The vapor pressure of LP at 70 F is 127 psi, @ 100f is 196 psi and @ 110 is 230 psi.
The regulator is what sets the low output pressure to the grill.
You can sure use it as an air tank and not be worried at all at 100 to 150 psi.
Had one, did that, worked great till I got my own compressor.
Galen
Jerry Gibbs
>Harbor Freight sells a 5 gal tank complete with valve and guage for $30 plus shipping. The tank looks larger than the propane tank. Not sure of any savings. Jerry Gibbs
Tank
>Thanks Galen. The regulator did, indeed, throw me off. I'll have to check my tanks to see if they're stamped with a pressure rating. Given your info, I'm a little surprised that these tanks aren't required to be hydro-tested periodically.
