Production techniques for better working - long
Stephen Kirk in Quakertown PA
>As I grow in my abilities, I'm now looking at how I go through a project from start to finish. I want to see how I work faster, better, more accurate and as safe as possible. What I am doing now is adopting large shop techniques into my small one man shop. I'm hoping this learning may help a few other newer woodworkers, as well. It's far from definitive and if anyone else has good ideas, be sure to add them in.
Overall - Have a scratch pad, whiteboard, something to keep notes, to-do, etc. Especially for part time woodworkers, we forget things from day to day, week to week.
Step 1 - Have a plan. Any plan is good, even just a napkin sketch. It will tell you what you are doing and keep you from constantly rethinking as you move through a project (or while in the middle of a cut!). We part time woodworkers can make good use of a notepad on the bench.
Step 2 - Gather all of your materials. And I mean all, including hardware, screws, dowels, etc. If you don't, you will surely be missing it when you want it. Don't know what you need - see step 1.
Step 3 - Bring all stock to near size (length, width, thickness). If you can, set it aside on sticks to acclimate for a week or 3 (longer, the better, but sometimes we can't wait long). Label things well. While waiting, you can start planning other projects, work out a finishing strategy, purchase a new tool ...
Step 4 - Bring all stock down to finished sizes. I do often leave a bit on parts that can be variable such as the length of parts in a cabinet which you cut to fit. Re-label if necessary.
Step 5 - Joinery. This is our bread and butter and where we have fun. I'm finding that doing everything before this makes it more enjoyable as I don't have to stop dovetailing to joint and plane more stock, for example.
Step 6 - Assembly. Do your dry fitting, adjusting and put it together. This was a tough area for me, but as I do things in a better order I find that assembly gets easier.
Step 7 - Finish. This is an area I need to work on, but basically apply the finish our your choice (I only have a few methods for finishing so far). If you are inclined, you can move finish before assembly if that works for you (taping off glue joints, etc)
Step 8 - Enjoy! Plus move on to the next project. Buy more tools.
Re: Production techniques for better working - long
Good points
>This reminds me of a talk I used to give called "Working Smart." You may have been there when I gave part of it at the Lehigh Valley WW Guild meeting several years back. The common thread here is the emphasis on planning and saving steps, and you're right about the time you save and the increased satisfaction in your work. You get more done with less angst so you have more time for other things. Like buying more tools. :-)
Thanks for the post. Anyone else have something to add to Stephen's list?
Chuck in ND
>( I want to see how I work faster, better, more accurate and as safe as possible. ) Not a bad plan, but you don't address the safe as possible issue much. Fast and safe shouldn't be in the same sentance when it comes to the shop. A tool maybe safe and faster, but not a shop. I'd rather call it efficiently. And the key to that is as strange as it may seem, is patience in my opinion. Use your head, your working in a hazzardous enviroment, and mistakes also cost time and materials. If you can't find the time to do it right, how are you going to find the time to fix it? Especially when it involves body parts. Don't push yourself, and don't let anyone push you. Try to enjoy it and not make a job out of it. And one last thing, don't forget about air quality in the shop, a good respirator, and hearing protection when needed.
>Lot of great points. Safety is so big it often becomes it's own talk, but we must realize that it plays a part in everything we do.
I've looked a lot at air quality lately. I keep a full face respirator handy and one of my next purchases will likely be a good dust collector. And I haven't ruled out an air cleaner. I'm glad to see many new tools are incorporating better dust collection these days.
We can certainly talk about how to include safety into a process. When working in discreet steps, it's easy to create one, safe routine to do things and stick to it. For instance, if ripping is done all at once, it's easier to set up the splitter and guards and be in the right mindset to work safely. When a worker jumps around steps in a project, it's easier to not bother to put the splitter on for just one cut.
Thanks!
Re: Good points
>Thanks Ellis. I may have just heard this a while back from you. I've also picked up many points along the way, especially when taking some courses. Good instructors have to work in finite steps in order to keep a class moving. I found learning that was as useful as the item I was building.
Learning a good production process is also guiding my tool purchases and helping me spend wisely. Plus it's useful for determining how to lay out a shop effectively.
Preserve Tool Set-Ups/Settings As Long As Possibl
Joseph Mulherin, Sr
>Stephen, you have made some extremely valid points in doing our woodworking. I have the Shopsmith and have been doing exactly those points for over 34yrs....mainly because making all the cuts on the saw setup before changing over to another operation like using the drill press setup. Also, when I start making something from a set of plans, I first make a pattern from hardboard or 1/4" plywood to double check myself over the term of the project... and if I want to make another one, I have the pattern already..... like when I do some turnings for legs. I have the lathe duplicator which I can setup and copy anything perfectly as long as I have the pattern setup to follow.
Right Tools for the Job
>Your post may tie in with a thread on the Hand Tool side. In my experience power tools are great for many jobs. Cutting, flattening, thicknessing and many other tasks are arguably faster done with power tools. But one should not assume that power tools are the most efficient solutions in the shop, nor produce the highest quality results.
Often times hand tools can do a task far faster and many times better than power tools. In the time that it takes to set up a particular task or create a jig the job could have been long finished if done by hand. I find that my efficiency is enhanced when I identify those tasks that are better done with hand tools. A good Japanese or western joinery saw for example can reduce work time considerably for many tasks. Same for many other hand tools.
So I believe that when equipping a shop for productivity one should never overlook the benefits of hand tools.
Tom
Re: Good points
>As a 1-man shop with limited space and most all tools being mobil, I must set up a work flow of operations, otherwise, a goodly portion of my time is spent pushing/pulling iron around.
Example:
1. Select rough stock and lay out sections to be used for each part.
2. Rough cross cut into sections appropriate for the planer.
3. Number each piece indexed to a list of parts.
4. Joint one edge and one face of each rough piece.
5. Rip to width + 1/32
6. Plane to final + 1/32
7. Drum sand to final thickness
Each step in the process gets me "finished" with the respective tool required [that then gets put back into its storage slot], and also promotes final fit because the set up for each step spits out uniformly dimensioned stock. If I screwed up on the step, everything's still the same and any adjustment needed to the plan can be carried through the whole piece. This becomes the ultimate method to hide your mistakes. |;-}}
It also keep waste to a minimum.
good ideas and a comment
Bill Tindall, E.TN
>These are all excellent steps to follow. One can't over plan a project.
If the lumber is anywhere near dry, it does not take more than a few days to acclimate provided there is good air access to the parts. Many professional shops buy KD lumber from reliable sources and use it immediately, successfully. So, typically don't let this step impede progress. At the rate I work it is never an issue!
Wow! You sure jogged my memory on this one Ellis.
Art Silva
>Way back, I will not mention the date, I talked to you about speaking to the guildmembers (read Dragooned). You mentioned the total work was quite long, but you would be glad to cover the first part. The evening went well, and we looked forward to hearing more at later meetings. I guess you can see where this is going. I'll have to load up on some Dunkin Donuts & coffee before I stop by. See ya.
AZ, Colorado Springs
>I'd emphasize making a sketch of the project. This helps with the orientation of tails & pins on dovetails, which boards need extra length for tenons, and where the odd parts are in tongue and groove or shiplapped panels.
Also, making a mock up of the project beforehand, from cardboard or some other material, not only validates decisions on overall dimensions and proportions, but also helps me to think through the orientation of the joinery.
These aren't really production activities, but I've found that the more thorough the planning, the fewer the "V8" moments ("dang, I should've thought of that") and spoiled boards in the shop.
Stephen Kirk in Quakertown, Pa
>Haha, V8 moments! Yeah sketches and mockups certainly do work well! Of course in the winter a little extra firewood comes in handy.
