Router for router table
David A Dircksen
>I'm looking for sugestions for a router to mount under a router table. I had a Ryobi for years but it finally died. Any sugestions? Thanks
Re: Router for router table
Milwaukee 5615-24 *LINK*
Grant in Iowa
>If you want a small good router for cheap then check out the deal on this Milwaukee linked below. If you buy the wrench to fit it (search on Milwaukee router wrench) you can make abov ethe table adjustments. And you still have the plunge base for portable use. All for $119. A friend of mine has this router, and is very happy with it. And I doubt you can beat the price.
If you want a monster router for panel raising and such then I suggest the Porter Cable 7518. I have run one in my table for 5 years with no complaints whatsoever.
Regards,
Grant in Iowa
Milwaukee 5615 kit on Amazon
>Good Morning David,
I am on my 2nd router table, and retrofitted the table top to accept a JessEm Mast-R-Lift which houses my P+C 7518 router. That combination represents a high standard of capability and reliability. However, it is costly and took me awhile to upgrade to where I am now. For years, the bulk of my router table use was adequately handled by a P+C 690 motor. They have plenty of power, about 10-11 amps and don't weigh too much. Bit changing can be done by easily popping the motor and base out of the table top for easy access. For a person starting out, its a relatively inexpensive bullet proof machine. Virtually all well known brand names like DeWalt, Freud, P+C, Makita, Bosch, Hitachi and Milwaukee have great routers which can serve very well under a table. A 2nd base would permit the motor to be used for hand-held work. I don't see how you can go wrong selecting any one of them. You'll need a bigger machine if you intend to swing large diameter bits, for panel raising as an example.
George
Bart Goldberg
Re: Router for router table *LINK*
Bart Goldberg
>Hi - I would strongly suggest you purchase a router that provides above the table height adjustment. There are several models that have come out over the last few years that includes this. I would also suggest you get a router with a 3+ hp motor. Here is a link to the Milwuakee that has these features.
Work Safe
Bart
Milwaukee Router
