OT software deletion problem
Robert R. Clough - Thorncraft
>Some time ago I installed Avira Anti Virus, personal. It was not what I wanted so I uninstalled it. However, there are "pieces" of it still around. When I go to Control Panel and Add/Remove, it still shows up. I cannot remove the "remains". I get a message "Setup could not determine the feature control file or was not able to read it correctly." If I Search for it, nothing comes up. I have no idea where it actually resides.
This is most annoying as I wish to download AVG Anti Virus (paid for). I was told by AVG that Avira could disrupt my new program.
How can I get rid of the "remains"?
Re: OT software deletion problem
Chuck W
>you could try to reinstall it and then uninstall while in safe mode.
>I tried that a while ago. Avira refused to install telling me that it was already running!!!!! (Where?)
Chuck W
>right mouse click on the navigation bar at the bottom and open task manager. look for the instance of avira that is running and manually stop it.
Dan Donaldson
>Couple of things. Stopping it in taskmanager is only temporary as it will restart the next time you reboot. Try bringing up taskmanager and looking at the running processes and see if you can figure out which ones are for avira. If I remember correctly, taskmanager will also give the folder that the processes are running from so you can figure out where it is. Be aware that the processes may not have the name avira in them. You may have to do a bit of detective work to figure out which ones they are.
Jerry Nicholson
>AV programs seem to leave bits and pieces of themselves all over the place. For instance, I have had to do extensive registry trimming to get rid of all of Norton Antivirus.
Jerry
del schisler
>go to start and open up run and put in their regedit it will take you into regestery and open up HKEY down to software look in their for all thing's that have that name on it and delete You can look in all the other folders and if you see that name delete it Don't delete any other names than shut down should be gone If the name is still in the control panel and no bit's across from the name their are nothing left but the name
you have to delete by doing a right nouse click
Re: OT software deletion problem *LINK*
Ken Krawford
>Robert you might want to download and install Microsoft Install Cleanup and see if I can remove it. I've also had some luck with Revo Uninstaller.
Good Luck.
Ken
MS Install Cleanup
I would be a bit nervous
Dan Donaldson
>If you don't know exactly what you are doing, editing the registry may not be a good idea. If you make a mistake, you can hose the whole machine, and it does everything in real time so there is no undo or even a save command.
I agree, Dan.
>So far I've been able to get rid of all but 4 instances using Revo. I think I'll let it be for a while. Now I've got to find a way to delete the AVG bar at the top of the window - the one that says AVG - Yahoo, search, etc. It's a nuisance in that it cuts down on space. No major problem, just a nuisance. If it can't be done, so be it!
Re: I agree, Dan.
Dan Donaldson
>Which browser?
Re: Firefox NM
Kneale Brownson..Back enjoying CO snow
>Right click on the AVG with colorful patches, you'll get a dropdown box with toolbar options that lets you eliminate that toolbar.
del schisler
>nothing wrong with going into reg ONLY delete the name of the item you are wanting to delete Been doing comp for 19 yrs Just take it somewhere than Let them do it
Another program that will do it is Hyjack this But only put a check mark in the program you want to get rid of It will take it off
Dan Donaldson
>True, but if you make one mistake, you are done. Delete something accidentally and there is no undo, it is gone forever. People get away with it all the time, but they should be aware of the risks before they try it. Mess it up and it is usually a complete reload, which with a Windows box is not fun ;-)
