We value your privacy.
>My daughter gets whooping cough occasionally and it's suggested that we run a humidifier in her room at night. Her room has an oak floor and I run the humidifier (non-heated and doesn't have a fan to blow the moist air upwards) on the floor. The problem is, the mist condenses on an area of the floor within 2 feet of the humidifier. Is this because the floor is colder than the rest of the room at night? Would it help if I elevated the humidifier or would the moisture still find its way to the floor?
>You might call the floor the "first condensing surface". Basically the cold spot where the moisture condenses first. That spot has reached the Dew Point. I don't know for sure, but I would think this is going to get worse as the weather gets colder and the floor gets colder also. If you wet that spot every night, eventually it will stain and damage the floor.
Raising the humidifier might help. That might give the humid air a chance to mix with less humid air before it reached the floor. (The Dew Point is lower/cooler as the RH goes down.)
Another approach would be to warm the floor. Don't know how you would do that. Perhaps one of those heated foot warming mats some of us get to put in front of the lathe or some other tools. You could shine a heat lamp on the area or even one of the old fashion incandescent light bulbs. (This is a place a CFL bulb should not work because it does not put of much heat.) The heat form the mat or bulb should not be wasted, it would just reduce the load on your heating system slightly.
You could raise the temperature in your daughter's room. Don't know how much you would have to warm it to stop condensation on the floor. Try warming the room to the point you can't see her breath in the moon light.
And you could get a different humidifier that either warms the air more or has a fan to disperse it better. Or you could install a whole house humidifier. Do Be careful with humidifiers. They tend to be mold factories. So Respiratory therapists have stopped recommending them because they produce mold which is more aggravating to the patient than dry air. Whatever you get, take the cleaning instructions very seriously and perhaps double up on them. The mold issue is the bane of the industry and they are in denial. Thoroughly clean it at least twice a month or even once a week.
>I've purchased several over the years, and they've all said to keep the device elevated from the floor. We use a jelly roll pan (cookie sheet with short sides) under the humidifier and put it on top of a dresser.
>Would you mind Sharing the Model number or something that would allow me to get one? I actually want a humidifier. As I approach geezer-hood I need one more and more. Do you just run tap water in yours? Do you use any of the anti-mold solutions? Is it noisy? Does it use significant power?
>First, my humidifier is just a cheap model with no fan or wick, just the small motor inside that makes mist. Anyway, I raised it up about a foot off the floor last night and had no probs with moisture on the floor.
I do have another one that uses wicks and has a fan so I'll probably order some new wicks and use that one.
