THE WOODRAT IS BACK!
Finally sorted the wood..
>"Split" the wood. The other two guys didn't take that much (relatively speaking). So I ended up with a rather large couple of stacks. Of course I won't be able to park the cars in the garage for the foreseeable future. I guess I should start on a "wood shed" to store lumber and other things.
Which leads into my question.
How long should I leave the boards? They are up to 16' in some cases.
I can build a storage shed without a permit if it is 150 or less sq. ft. I would like to store lumber along the sides and the lawn tractor and stuff in the center. I was planning a 12' x 12' shed that is "portable". I could double up the plywood on the bottom and use 2 x 10" floor joists and put the shed up on piers. Simple easy construction with no cutting of plywood for the most part.
Any thoughts about board length?
TIA
Re: Finally sorted the wood..
Lewis Dodd
>Nice! Congrats. Some of that stuff4/4 and 8/8 ?
Lewis
"stuff in the center", yup, MORE WOOD!
Dick Coers
Jesse Cloud
>No easy answer on the board length unless you have a good idea what you will be using them for. I would probably make one piece as long as possible (after cutting off checks and analyzing for any flaws that might suggest a different cut (e.g., if you have a big flaw in the middle, cut it out now and keep the two pieces left).
You might consider just a few landscape timbers to get the lumber off the ground, then sticker and cover with a tarp.
Yes.
>Or rather 4/4, 5/4, 8/4 and 10/4.
All in the garage right now.
>Where it will stay until I get the shed built. All "stickered" and stacked on off cuts (2 x 2 and greater) that came with the load.
John Veerkamp, Western Mo
>Jl,
Unless you're going to be doing woodwork trim in a house, you'll seldom find a piece of wood longer than 6' in furniture. I think if it were mine I'd cut most of the long stuff into 6-6-4' pieces and some into 8'. 15 ' into 7&1/2 12' into 6' and anything under 12 ' leave as is. that way everything will fit into your 12' shed.
My 2 cents.
John
My rule on board length is ...
Grant in Iowa
>Don't cut a board if you can manage it until you know the length you need.
But if I HAD to cut the boards down, I'd leave them as long as you can store. If you plan to build a 12x12 shed, maybe cut the 16 footers down to 11.5' and a 4.5' board. I would, however try to leave anything cut off at least 30" long or so, to try to make it useful for something.
I too would be interested in what others say on the subject.
Have you thought 3 dimensionally in your existing garage? Might there be a way to do some overhead storage for some of the longer boards?
FWIW,
Grant in Iowa<---unpacking some Craigslist veneer I just picked up...I think there is a small flitch of chestnut leaves in there...maybe if I am guessing the indentity right.
never pre-cut a rope or a board
Bill Tindall, E.TN
>My grandfather emphasized a philosophy that one should never cut a rope because tomorrow you will need a piece slightly longer than what you cut. This philosophy has been born out time and time again in lumber. Every time I make something I reject possibilities because the cutting I need is 1" more than either the length of the board or the distance between defects. I would go to great lengths to avoid cutting the lumber into shorter, and hence more wasteful, lengths.
That said, if I was forced to fit lumber into a 12' storage building then I would cut it 12'. But, if I was building a storage shed I would make it 14 or 16' long and less wide. Put the long stuff on top and park lawn mower in front. Side access for a lumber rack is not particularly advantageous. The PIC shows racks we have found easy to construct and functional. Each "bay" holds about 500 bdft. A divided rack section 42" wide x 8" high (like in PIC) will hold about 3000 bdft of 12' lumber.
You are way over thinking what kind of floor you need.
don't sticker and don't tarp
Bill Tindall, E.TN
>there is nothing to be gained by stickering and tarping lumber stored in a garage. In fact, dead pack it as tight as you can get it to hold down moisture gain. A tarp might keep some dust off it but it will not significantly affect moisture regain, or loss.
piling information
Bill Tindall, E.TN
>Ideally you need to get support under the sub-stacks about every 4 feet. No benefit in closer spacing for lumber that is dry, and hence stiff. . Not sure why you have the sub stacks separated. Normally one dead packs lumber as tight as possible.
I would have gotten the pile off the floor somehow (cement blocks for example) and starting with the longest material made one closely packed stack organized by length, long on bottom and short on top. If the layers get out of whack due to irregular thicknesses, then some sticks are useful for getting the layers back in one plane. In this case anything will do for a stick so long as they are the same thickness. If you use sticks in more than one layer it is very important to have the sticks for each layer aligned vertically with one another to prevent bowing the lower layers.
Re: piling information
>Sub packs are separated by species and size with a lone ash 8/4 in the oak layer. I put stickers on the floor at ~4' intervals. The stickers are over the preceding stickers.
Nice haul.
Victor P
>I've been following this adventure since your first post. IRS auctions sure had a lot of wood to move. Looks good.
Victor
