HSS Taper Drill Bit
HSS Taper Drill Bit
HSS Taper Drill Bit
davhamm
>Has anyone had a problem with the lee valley HSS Taper Drill Bit breaking? I bought the set several years ago, but have not used it much and just had one of the bits break off in the wood (pine) fortunetly leaving it in place will not cause a problem cause none of it is sticking out so I don't know how I would get it out if I had to.
Just wondering if this is a known issue or just a freak.
Re: HSS Taper Drill Bit
Call them..
>They have the best customer service. They will tell you if there is an issue. They may even replace your bit. You might get it out with a screw extractor.
