Oak color and table repair - apprenticeship contd
Nathan
>My apprenticeship continue to be an exciting odyssey and my teacher a great guide. The next topic that he wants to tackle is joinery, starting with bridle joints, but we haven't got there yet due to some digressions.
First, another apprentice came to the shop. He's not as serious about learning woodworking as I am so he's a bit of a liability in that respect, but he's an OK guy and I'm sure we'll get along.
Our teacher has responded to this by giving him accelerated instruction in the topics we have already covered, while involving me in other work. That "other work" has been really neat. First he had me work on oak church-bell headstocks they were making. They had two long mortises on each side of the bottom, open on the far ends, for some kind of steel or iron insert that will be attached to bearings to allow the bell to swing from side to side. He had done most of the mortise already on the shaper but needed the rounded part squared off. He gave me a large joiner's chisel and had me hone it up and square off the mortises. He inpected my work closely and had me go back several times to clean up the bottom of the mortises.
Then, due to some serendipity, the people from the neighboring building brought in an old, beat-up, round table made out of pine and hide glue that my teacher said was cheap furniture made in the 1930s. It was in bad need of repair. He immediately got out the hot plate and showed me how to mix and prepare hide glue. Then he took the table apart - it readily became about 6 or 7 pieces. We glued the top back together with fresh hide glue and to ensure that the top stays put on the base he had me drill holes for eight dowels - using a brace. I quickly found out that drilling dowel holes straight with a brace is not as easy as it looks. My dowels were going in all directions, but somehow - with a rasp and some pounding with a dead-blow hammer - I got it put together and we glued up the base.
Then my teacher showed me how to make wood putty out of chalk powder, hide glue, and ochre (except we didn't actually use the ochre since the piece was to be painted white). Since the piece was in pretty bad shape and our repair basic, though careful and thorough, I had to use liberal amounts of it to fill in all the voids and places where the paint was chipped. Then I sanded the whole piece with 100-grit sandpaper and mixed up more putty to fill in more voids that I found on closer inspection.
Then, by chance, one of the guys was spraying white primer so my teacher had me carry the base and top upstairs to the paintshop. I saw the base after the first coat of primer and was shocked by how many new voids appeared. Peter, the employee who was spraying, said he was going to have to re-putty and re-sand the whole piece. I was pretty discouraged about that but my teacher intervened and said it was normal in a piece like this for imperfections to jump out after the first coat of primer. They showed me the two putties used in the paint shop - a polyester finishing putty (the kind you add hardener to) and an acrylic putty.
Anyway, then I went back down to where my new fellow apprentice buddy was practicing his chiseling technique. My teacher took me to the wood stack and pulled out a 8"x6" piece of oak 6 cm (2.36-in) thick (I guess that'd be something between 9/4 and 10/4 in the States?). He asked me what species it was. I replied Oak. "You got that right" he said. Then he showed me some of his better boards - he had Gaboon, Mahogany, and Sapele, plus a bunch of others that I don't remember because they went by so quickly and I was too excited to be in such close proximity to exotic timber.
Then we went to the jointer - a huge hunk of cast iron with very long beds and he proceeded to joint both sides of that 8" long piece of oak. He told me why that was a procedure one had to be especially careful when doing. He used a push sled and took the beginning of the cut very slow.
This piece of Oak was quite something. When I get my camera back I'll try to post a picture of it. It had a beautiful rich milk-chocolate brown color that I've never seen before in oak. Anyway, he had me mark out three mortises along the edge and chisel them out to a depth of 3 cm (1.2-in) using a marking gauge. While I was chiseling them, he stopped by and said "the rest of that piece of wood will make a nice turning blank". When I was done he said the mortises were good and then took the workpiece to the bandsaw and proceeded to saw off the edge where my mortises were, so you can see the inside of the mortises.
He kept the rest of the piece as a turning blank. I mentioned that I want to buy a lathe but as yet haven't found room for it in my shop. He said that learning to turn wasn't a matter of one afternoon, but since I was interested in turning, he'd "put me in front of the lathe and have me stand there all day". Hearing that sent me into rapture. He opened the turning-chisel cabinet for me. I mentioned that sharpening them was challenging and he said he does it by hand, and promised to show me.
By the way, Fred, when we were finished re-gluing the table base he gave me a cabinet scraper and had me scrape clean the faces of the two long thick planks they have set up between sawhorses for glue-ups. He showed me how to hold the scraper and mentioned that it was dull - "later once I show you how to sharpen it, you'll see it will something different entirely" he said.
I'm wondering if there are different techniques for sharpening cabinet scrapers. My teacher's is basically a strip of metal, having been ground down over the years. I'm wondering if he uses the hard metal rod at all - maybe he just hones a burr onto one side? We'll find out.
Re: Oak color and table repair - apprenticeship contd
Fred Davis
>Nathan,
I don't believe I have ever seen the level of excitement and anticipation you exhibit in your posts.
Not many have the opportunity your enjoying , so make the most of it, you'll be glad you did over the years.
About turning a hook or burr on the edge of a cabinet card scraper , whatever works for the teacher will undoubtedly work for you, all it takes is practice.
FredD
love these posts
Simon St.Laurent - Dryden, NY
>I'm very jealous of your hands-on learning, but reading these posts is excellent.
Thank you for sharing, and enjoy your work!
Me, too!
Bruce, a MN Galoot
>I'd give eye teeth or some other body part to have the opportunity you have. It's good to see that you're enjoying it so much and that we get the benefit of your posts.
Keep them coming!
Bruce
Thanks for the feedback
Nathan
>Thanks to Fred, Simon and Bruce for the feedback. I realize the stuff I'm learning at the shop is pretty basic, and my descriptions are probably unnecessarily long-winded, so thanks for reading. I enjoy writing about my experiences, so I'll keep on doing it as long as someone is interested.
I am interested also, thanks
>I enjoy your posts and wish I had the opportunity to do what you are doing. Squeeze everything out of it you can.
