lvl beams
lvl beams
lvl beams
Fred Steiner
>Can I span a 20 feet with 1 lvl beam? Do I need to double the beam?
Re: lvl beams
Yes, No, and Maybe
>You have asked a How high is up question.
We would need to know a lot more before we could answer your question. What would the beam be supporting might be chief among the missing information.
Then, there is the question of what size the LVL would be. A huge LVL might span 20" if it is lightly loaded. I know they come in many widths. Not sure if they are all 1 3/4" thick or if they make some that are 3 1/2" thick.
Ask the seller. LVLs are engineered. You tell the seller what the conditions will be and they have a staff engineer tell you what will work. They will do that much for free.
Re: lvl beams
In That Case . .
>"Depends on what your smoking."
Re: lvl beams
Span chart
Richard Jones
>To answer your question directly, unless it's a ridge beam, probably not.
If you provide some more info, we can probably narrow the choices down.
Here's what I use for plan review at work:
http://www.ilevel.com/literature/TJ-9000.pdf
Hope this helps.
Rich
Re: lvl beams
Re: lvl beams
Lee Schierer - McKean, PA
>The LVL's for my shop were 18' long and there are three of them glued and bolted together, they came 20 feet long and were cut down to fit. As others have indicated you need to locate a dealer and talk directly. They will want to know the load, height restrictions and the construction of what the beam will be supporting. Once they have all the information, they will design a beam for you and tell you how it needs to be installed, including drilling instructions if it needs to be paired up.
Lee
Re: lvl beams
Re: Span chart
Fred Steiner
>Thanks for the good advice. Contacting the lumber yard on Monday.fs
