router jig for small hinges, help please
gary clarke
>I am taking a break from turning and I want to make some small jewelry boxes and use small hinges. Is there a jig that will help to install the hinges. Should I use a small router? Any excuse needed for a tool junkie. The sides of the boxes will be about 1/2 inch or 5/8 inch. Any help will be greatly appreciated. thanks
Re: router jig for small hinges, help please
jig not at all necessary
Bill Tindall, E.TN
>1. Hold in place, or spot glue with CA glue, and scribe around the hinge with a knife or anything sharp.
2. Use router, 1/4" bit and good lighting to waste out most of the mortise. With practice you can go right to the scribe lines.
3. Remove remainder of waste with chisel.
Agree, and
>Good Evening Gary,
Bill describes my method. I also use a laminate trimmer because its easier for me to see and control. Mine is a Harbor Freight with a clear plastic base, which I've used for 10 years or so. I think it cost me around $12 at the time. Not fancy, but superb for my needs.
George
Re: Agree, and
Brent Smith in Montreal
>I used to use a Beall hinge jig, but found that a marking knife, and chisel work much quicker. I do one mortise, butt the box and lid up against a flat surface and use a marking knife to mark the edge of the mating surface.
Re: Agree, and
>I agree. I do it with a trim router but I've also used my dremel with a router base. I get close and then clean it all up with a chisel to get right to the lines.
Re: Agree, and
gary clarke
>thanks, I will try it on some practice pieces.
works for me, too
DizD
>I like the HF trim router w/ the clear base also. I use a 1/8" bit with mine. FWIW I have found the ACE Hardware brass hinge to be the best of the off-the-shelf brands - very little play in the hinge. I now almost always set the hinge flush with back of box and put a 45 degree chamfer on the edge of the box and lid to act as a lid stop. Whitechapel has a description of the technique on their website. I just finished a small batch and for these I cut a piece of 1/8" plywood to the size of the box, cut the hinge mortise in it to use as a marking template for the box and the lid. Line it up flush with back and ends & mark w/ knife or chisel. Just remember not to turn it over to do the lid!
Bart Goldberg
Bart Goldberg
>Hi - I used to use a commercially sold hinge jig, but found it more trouble than its worth. Nowadays, I make a hinge template from 1/2" MDF. I lay out the exact pattern of the hinge on the mdf, and then cut out the hinge profile onto the template using a miter gauge and dado blade on my table saw. I can then use the same template to accurate cute all the mortises for the mating parts of my box with this single jig. Once the template is completed, I tape the template to my work using blue painters tape. I then cut our the mortises using a trim router and a pattern makers bit. After the router work is done, I square off the round corner with a chisel, still keeping the pattern in place to keep my chisel work straight and square. This only take a few minutes to do. My hinge mortises come out perfect every time.
Once you make this template, you can reuse over and over again anytime you are using these same hinges.
Regards
Bart
Jim Dillon
>Gary,
Agree with all the others. I've also used the Beal hinge guide and a trim router, but a homemade guide would work as well - though not necessary. I found the hardest part was getting the correct depth of the mortise: too deep and the top won't close, and too shallow and the the gap between the lid and box will be too large and unsightly. If you use a trim router with a depth guide, then use one leaf of the hinge to set the depth. And practice on scrap first to get the right depth and build confidence.
Jim
yes, I forgot that step-practice; advanced steps
Bill Tindall, E.TN
>Krenov trick:
There is another step for "advanced" hing work. Take a fine file (about 6-8") and do about one-two strokes around the bottom edge of the hinge. This puts a tiny chamfer on the edge. Now when you mark with the knife or marking gauge (the ones from Blue Spruce Tools Works are worth the money and that is from someone considered frugal(cheap)) the mark and hence the mortise with be a few thousandths smaller. The hinge will pop into this mortise like it grew there.
I find a drop of CA glue handy for temporarily holding the hinge in place while marking. I somethings go ahead and drill the screw holes while it is tacked down. Use a VIX bit to insure perfect alignment of screw holes with hinge. Keep it perfectly vertical while drilling or the hole will be off center.
Once one leaf of hinge is fastened align the mating part and mark the hinge position on the mating part with knife.
On a box I mortise the box first and then the lid. On a cabinet I do the door first and then the body.
You will need to temporarily fasten the hinge for marking on the mating part, unless you temporarily tacked it with CA glue. On a 3-screw hinge, temporarily fasten the hinge with 2 steel screws 1/8" shorter than that brass screws that will be used in the finished piece.
If you are suing brass screws it is safer to fasten the hinges loosly with steel screws to establish the threads and then replace with brass screws that will be snugged tight. This step keeps from stripping slots in brass screws, or worse, breaking off a brass screw.
Bart Goldberg
Bart Goldberg
>I agree with Gary - the depth needs to be set accurately prior to cutting, and test on scrap before doing it on the actual piece. I keep a scrap of the 1/2 MDF template material to use for setting the depth correctly and use the actual hinge to set the bit depth. If you cut to deep, you can always layer in some blue painters tape into the mortise till you bring the hinge back to flush. If you cut to shallow, the a little chisel work is needed to deepen the mortise.
Work Safe
Bart
