Milwaukee "body grip" plunge base adjustment
Eric Anderson
>The depth adjustment knob on the 5615-20 Milwaukee "body grip" router is accurate (6/32 = 6/32 actual depth) on the fixed base, but shows 6/32 = 1/8 inch actual depth when the router is in the plunge base (part no. 48-10-5600).
Does anyone have the plunge base for the Milwaukee "body grip" router? Have you checked the accuracy of the depth adjustment knob when it is used with the plunge base? What do you think?
Re: Milwaukee "body grip" plunge base adjustment
Eric Anderson
>The previous message is not clear as to why there is a tolerance problem. The problem is the GEAR RATIO, not slop or tolorance of the components.
Why not have the correct ratio on the adjustment gearing if the gears are there anyway. This is not a case of tolerances; it is a case of choosing the right gear ratio. It appears that the designer intended to use the knob only as a means to move the depth rod and not use the scale on the knob as it is used in the fixed base. For the life of me, I don't know why that decision was made. If the scale is there and used in the fixed base, why not use it in the plunge base also?
On the other hand, this router and the bases are just about the best I have used. The body grip fixed base is the most pleasant router I use (I have a second in a fixed base only that I bought when these first came out). The plunge base is a great addition and I bought the 2 base kit for about 60% of what the fixed base router cost alone. Additionally, the case (although it is huge) is a great addition. It opens like a clamshell with the router in its nest ready to go. You can put the router in either base and not be too particular about where things are when you close it (you don't have to be a packaging engineer to put it back into its case).
