OT: relocating hot water base board heat radiators
Dominic in Bucks County PA
>OK gang, time to tap into the collective wisdom here at WC once more.
During the "demolition" stage of my ongoing family room rennovation project I found the reason that the exterior wall was so cold during the winter. And if you guessed inadequate insulation, you'd be right on. My house is a split and this particular wall is comprised of cinderblocks. The meager 1/2" styrofoam that was there before just wasn't cutting it. So I want to stud the wall out and then insulate. This will also allow me to install some much needed cable TV outlets and well as relocate some very poorly placed outlets and wall switches. So it's for the best really. At least, that's what I keep telling myself......
But (and there is always a big "but" Dotty) this wall happens to be where the base board hot water heat radiators are (they're still called "radiators", right?). I need to cut the extisting water supply/return pipes and move them out from the existing wall.
My questions are:
- Have any of you done this before and can you offer any tips?
- Wild idea here: in lieu of sweating the copper pipe in, can I use compression fittings? Just a thought because they are EASY to use and I can customize the install easier. And I HATE sweating in copper pipe!
- Are the new models of these base board radiators any more efficient that the older ones I have (they're from about 30 to 40 years old).
Thanks in advance
See ya around,
Dominic
