Shopmade Long Reach Drill/Driver *LINK*
Bricofleur
>Hi guys,
I want to share these two shopmade long reach drill/drivers ready to work hard to drill or drive in hard-to-reach tight and narrow spots.
Since I had two old chucks from worn out cordless drills, I bought at my local hardware store a 36�� long 3/8��-24 fine threaded rod that I cut with a hacksaw at 12�� and 24�� long. Note that the 3/8��-24 fine threads are the standard for drill chucks.
I screwed a chuck on each threaded rod and I locked them up with a nut, very tight, directly under the chucks. Then I slipped on the threaded rod a 3/8�� inside diameter transparent vinyl hose, that I also bought at my local hardware store in the plumbing department, to protect my fingers and the rod from rubbing materials. Note that I left about 2�� without vinyl hose at the other end of the rod.
They fit in 3/8�� drill/driver chucks or bigger.
To see all the details and more tips, click below.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
More details and other tips
Re: Shopmade Long Reach Drill/Driver *LINK*
>Good Evening Serge,
A very nice, practical, and inexpensive innovation. I've got a couple left over chucks which I now know how to make use of. thanks,
George
GalenV in Iowa
>I too have the spare chucks so may adapt one as you have shown.
I actually mounted one to a short bolt that I cut off the head to fit in my drill press chuck. The large chuck would not close down on a small bit when I needed an accurate small hole drilled.
As I write this the light came on over my head! I can use the same small chuck on the lathe. It will handle small hole drilling better than the 1/2" chuck I have for it.
Galen
Clint Searl
Clint Searl
>All it needs is a little LED headlight.
Clint
Bricofleur
>Thanks Galen,
Sharing ideas (or lights!), this is what it's all about here.
Best,
Serge
http://www.atelierdubricoleur.spaces.live.com
