Mitered Muntins
Mitered Muntins
Mitered Muntins
Mark Salomon
>In some of his earliest glass door cabinets G. Stickley mitered the muntins. Does anyone know how these joints were crafted? It seems like the mitered muntins would be very weak and their strength compromised if the miters were created by anything other than veneers???
Re: Mitered Muntins
Re: Mitered Muntins
Ed Mulligan, Cape Cod MA
>The Encyclopedia of Furniture Making by Joyce is a good book to have for reference about your question and many others.
I don't know how Stickley made the joint. The old simple way is to just butt the joints, glue and reinforce with canvas strips glued on. The new simple way is to butt the joints and glue with cyanoacrylate (Super Glue). The glass panes add a lot of strength to the finished assembly.
The stronger technique uses splines to reinforce the joints. It's depicted clearly in Joyce.
Ed
Re: Mitered Muntins
Funny you should ask *LINK*
Bob Lang
>I'm working on a reproduction cabinet with this detail right now, it will be featured in an upcoming issue of Popular Woodworking. I wrote a blog post about the joint a while back, you can read the whole post and look at my drawings at the link below.
My best guess is that it's a variation of a lap joint; I'm making a mitered recess in the center mullion, and a matching lap on the cross pieces. Looking at the grain patterns in original pieces tells me the center mullion is one piece, but the cross pieces are individuals. These parts are only an inch and a quarter wide, and with a rabbet for the glass there really isn't any practical room in there for splines or tenons.
I'll try to get a picture on the blog of the door joints in progress. It's pretty interesting, but as you may imagine a bit fussy and tedious. I did decide to change the joinery shown in the drawing where the muntins meet the outer door stiles. I found three different variations of that joint in original pieces, and instead of the full miter at this point, the miter only goes back to the edge of the rabbet for the glass. That leaves more meat in the stile for the tenons.
This is all on a small scale, and it looks like the joints in the center will be strong enough.
Bob Lang
Mitered Mullions on the Pop Wood Blog
Re: Mitered Muntins
Re: Funny you should ask
Mark Salomon
>What thickness stock do you use for the muntins--do you find that you need thicker stock than you normally use? Your photos of practice work shows a fairly thick stock. Thanks for the link, it really helps.
Re: Mitered Muntins
Bob Lang
>For the real thing I'm using 13/16" x 1 1/4". The test pieces in the blog are probably closer to 7/8" and they don't have the rabbet. Could be that they look thick because they are narrow. From the front of the finished door to the glass is 1/4".
Bob Lang
Re: Mitered Muntins
Mark Salomon
>Thanks, I'll give it a try. I've promised my wife a couple of Stickley 70 music cabinets for her music. Although the miters are not authentic to this cabinet, it would add a bit of interest to an otherwise chunky cabinet. I'll keep checking your blog for progress/pics.
Re: Mitered Muntins
Coincidence strikes again
Bob Lang
>That's the cabinet I'm making. I couldn't find an original example of one with the mitered doors, but I've always been taken with that detail. Almost have the door together, and it's very cool.
Bob Lang
Re: Mitered Muntins
Re: Coincidence strikes again
Mark Salomon
>Wow, are you using hammered amber glass also?
Re: Mitered Muntins
Re: Mitered Muntins
charlie belden
>If you want the look - but don't have to go with the "traditional" method - you could try a pair of cope and stick router bits. Sets for 3/4" and thicker as well as 1/2" or thinner are readily available. The bit for the coped part leaves a short tenon to go in the slot for the panel - in this case glass.
Either way, if the edge has a profile butt joining is out unless you want to do a fair amount of carving.
BTW - a 5mm DOMINO loose tenon would let you miter the frame's corners and loose tenon join the - the muntins could also be loose tenon joined if you go with a butt joint.
