Jumping the "Weekend Accomplishments" gun
Rod Peterson * Ormond Beach
(crossposted to the Turning Board)
A couple of years ago I posted about the magnetic switch conversion I did on my Delta DC-380 planer. In the last paragraph I mentioned that I now have a surplus of one OEM Delta On/Off switch. Well, I read or heard somewhere that a remote switch for a lathe is a good idea and it struck me that putting that surplus switch to use might be a good project. Here's what I came up with:
This is the headstock with the original 46-700 switch to the left of the speed handle (key removed), and the new switch next to the banjo.
Here's a detail showing the strain relief I installed in the headstock cover and the 8' cord that comes through it (top cord is the one from the motor). Internally, Delta had insulated female spade lugs which install onto lugs on the OEM switch. I just installed male lugs on the new cord, unplugged the wires from the old switch, and plugged them into the new cord. I didn't even need to tape or shrink-tube the connections. And, it's completely reversible, should the need arise to revert to the original configuration.
This shows the switch box at the other end of the 8' cord sitting on the bed of the lathe to the right of the banjo where it might be situated in a real life faceplate turning scenario (I haven't actually used it yet, although it is tested and functional). Naturally, for spindle turning, it's likely to sit to the right of the tail stock.
The box is a garden variety outdoor electrical box. I had to do a little surgery on the interior tabs because of the bolt/nut/coupling assembly which attaches both the switch unit and the cover to the box, but my Foredom was more than up to the task (a Dremel would have worked fine, too, or even a file).
The two rare earth magnets epoxied to the bottom of the box. There are four bosses on the box (came that way) which keeps the magnets from actually touching the surface, which significantly reduces their "grab." If you've played with rare earth magnets, you know that even these ½" babies are really strong. If I feel like I need a little more grip, I can take a couple of swipes over each boss with a file until I get it like I want it.
Here you can see the box sitting atop the headstock—a place it will never be when the lathe is in use, as the cover is plastic and there's nothing to keep the switch box in place. Shudder—I don't even want to think of the implications of that cord getting involved with that faceplate! This shot is just to show the length of the cord and to illustrate the flexibility I now have in locating the switch.
This is a more likely alternative resting location which has the best “grip” of the headstock area possibilities.
I'm sure the real experts will say I'm just chasing a bad dream by a project like this—in fact, I'd really like to put a VFD (variable frequency drive ) on it and eliminate the Reeves drive—but since I'm pretty sure even a $2K lathe isn't a prospect, I need to take my improvements where I can find them. Realistically, a Oneway or Stubby is not in my future.
Rod
