Minwax Polycrylic - food safe?
Stephen Kirk in Quakertown, PA
>I'm finishing the grinder box for an apple press. I finished it, so far, with one coat of Minwax Polycrylic. I had thought that was food safe, but now I can't seem to find anything that tells me it is. I was also under the impression that nearly all finished, once cured, were food safe. I see very few finishes listed as "food safe" these days. I'm a little fuzzy on the topic and hoped someone else had some good info.
Re: Minwax Polycrylic - food safe?
>Safe for "casual contact" or "lengthy immersion" or what . . . .?
Google Mixwax, go to their site and hunt up the MSDS for the product. That should answer all your Q's. BTW, the stuff ain't very durable as far as I've seen.
Jim Dillon
>Stephen,
I would guess that most acrylic finishing polymers are "food-safe" once fully cured. The potential problem comes in when traces of unreacted monomer remain in the "fully-cured" polymer. While I have never heard of toxicity issues related to a fully cured polymer (of any type), residual monomer, or degradation products from the fully cured polymer* can be suspect. Said another way, the monomer(s) that goes into making a polymer can be quite toxic, but once the polymer is formed and allowed to FULLY cure, the liklihood of a problem from the polymer per se is small. Now, the addition of an additive package (driers, surfactants, accelerators etc.) to the monomer mix changes things and all bets are off. Personally, while I am generally cautious regarding chemical toxicity issues, I think you should be OK. Now, the durability of the finish is another matter, as Mark mentioned. This advice is worth what you have paid for it 8-).
* The degradation products of some polymers (degradable sutures/coatings, for example) can elicit a very mild inflammatory response (due to local low pH issues) that the body can tolerate very well.
Jim
MN-If it'sQ-Mart food, yes
Justin Szeliga
Dave Anderson (PacNW)
>Polycrylic is a polymeric solution. There are few (if any) monomers present.
The biggest hazard is from all of the nasty solvents.
"DIPROPYLENE GLYCOL METHYL ETHER, ETHYLENE GLYCOL,N-METHYL-2-PYRROLIDONE, 2-BUTOXYETHANOL, N-BUTOXYPROPANOL, DIPROPYLENE GLYCOL MONOBUTYL ETHER"
Just make sure you dry it in a well ventilated space. Once the solvents are gone, the finish will be fine.
Food Safe vs. Non-Toxic
Howard Acheson
>Since the mid 1970's all finishes sold in the US are required to be non-toxic when cured. "Food Safe" is not a term that is recognized or defined by an governmental agency as far as I know.
Some manufacturer's will infer "food safe" because their product is made from non-toxic materials. But, there is no certification.
All finishes are safe, including paint
North of the Border
>sold in the US (which should all be lead-free) after they've cured (for at least 30 days) - Woodsmith # 179 - p.50.
Thanks All!
Stephen Kirk in Quakertown PA
