Insulation near fireplace?
Dominic Greco in Buck County Pa
>I'm in the middle of rennovating my family room when it came time to remove the circa 1970s paneling (yuck!!!) from the walls. When I removed the paneling from around the fireplace I found that there was no insulation.
The wall that the fireplace shares is not an exterior wall, but backs up to an unheated storage area. I was wondering if I SHOULD insulate this wall at all, and if I do, what kind of insulation should I use?
See ya around,
Dominic
Re: Insulation near fireplace?
>Yes, with something non combustible, like fiber glass.
Other insulations are fire resistant also. Cellulose is made of paper and is treated to resist fire, decay, and insects. I have pull out handfuls of it and set it on fire. It burns. Not as well as if it were not treated, but it burns.
PS, In those days......
>the 70's, the code required that the framing not touch the fireplace. There was supposed to be a 2" gap between the fireplace and anything combustible. It was always one of those mysteries as to how to cover the gap if you could not use anything combustible.
Bill Tindall, E.TN
>If you don't want to heat what lies behind then insulate with typical fiberglass batts. Flammability is not an issue. If the wood framing is ok, the insulation will be. After all you had paneling on this wall and it burns better than anything a house is made from.
>So I'm guessing that the paper backed fiberglass insulation is ok
>Thanks Bill. I sort of thought so. But I promised the wide I'd "ask someone who has done this before". Now I can say I did!
>I would peel the paper off it and thus the fiberglass itself into the space. Just out of an abundance of caution.
The paper is probably slightly more flammable that the paneling that Bill mentioned, and it is concealed where you may not notice it burning until too late. Worse yet, they use tar to stick the fiberglass to the paper. (Its the tar that is the actual vapor barrier, not the paper.) the tar is probably more flammable than either the paper of the paneling.
There is a process that goes on if you heat the wood over and over and it lowers the ignition point. If there were a flaw in the fire place that allowed heat to get tot he wood or paper this might happen. Extremely remote possibility, but you don't want to be the one that proves it happens.
Spray Foam?
Dustmaker Mike
>would spray foam work. Just curious?
>My local contractor's lumberyard is now marketing fire-code spray foam and caulk; you might look into that for the gap between framing and masonry.
We've been doing progressive remodels in our house over the last couple of years (YEARS of deferred maintenance - big remodels are hard to do yourself when you work full time), and insulating as we go. It's made a huge difference - so, yes, insulate the wall.
>In foam would work if it is the fire resistant kind. As you mention there is a Caulk/foam for this purpose. It is red and "Intumescent". (SP?) It swells when subjected to heat/fire. Used to seal between areas to prevent fire spread. Other foams may not be fire resistant. And the Great Stuff type foam swells when sprayed into place. A neighbor tried to insulate a cast iron bath tub with it and it easily picked up the 400 lb tub and tip it over. It was heck to get the foam out form under the tub. Be careful with foam, it could move the stud easily.
