Drill Press Laser Light
Tom Rex in TX
>Anyone have experience with one of these?
Woodcraft has one on sale for $30.74.
Is it worth it?
Tia
T Rex
Tom Rex in TX
Is it worth it?
Tia
T Rex
Re: Drill Press Laser Light
A.J. Hamler
>Not sure if mine is the same one they carry, but I'm not impressed with them in general. I loved mine when I first got it, but was disappointed by almost the second time I used the drill press with it. The two beams simply will not remain aligned correctly. I've reset them countless times, but every time I come back to use the drill press after a period away, they're out of alignment again.
If you can figure out a way to keep them aligned, I think you'll love it. Otherwise, you'll grow frustrated with them quickly.
A.J.
May I suggest...
Grant in Iowa
>You take the $30 and buy a good combination square. Or some other tool you are lacking.
Your mileage may vary, but I have never been even tempted to invest in laser guided anything. It just seems gimicky, and most of the lasers seem to have enough width, blurryness to be of little use for my desired level of accuracy.
laser level, maybe.
FWIW,
Grant in Iowa<---laserless in a large well outfitted shop.
I'll sell one for $10
Bill Tindall, E.TN
>One came with my drill press and I am too old fashioned to imagine using it. It sits unopened in the box it came it.
Robert R. Clough - Thorncraft
>I have one that is built in on the drill press. It works fine and stays aligned - but I seldom use it. A punch mark works just as well.
Charles Yawn
>Tom, I have a laser guide from Woodcraft. My opinion is it's somewhat flimsly and the reliability is questionable. I broke mine in two different places but was able to repair it. I do not totally rely on the crossed beams and end up testing the bit alignment with a slight bump to make an impression in the drilled piece. So I often wonder why I have it installed.
Charles
Re: Drill Press Laser Light - What AJ said...
Jim DeLaney, Austintown, Ohio
agreed with the punch mark remark 100%
North of the Border
Art Liebeskind
>I am almost embarrassed to say that I have the device and I like it a lot! That's why they have horse races and elections I guess. I use it all the time and it stays aligned.
Art Liebeskind
Not great if you have a fence on your DP table.
Scott in Montana
>Mine seems to stay in line alright, but with my low 2 1/2" fence it seems that much of the time the lasers are in the shadow of the fence.
Scott in Montana
Larry Clinton At Frankfort (Central)., Indiana
>I agree with Art. My Powermatic DP came equipped with the laser. I aligned it using a 1/32 drill bit when I purchased the press and it has never moved in over a year. I use it often and find it to be as accurate as using a punch for alignment. Can't say how the "add on" units work though.
