Drilling glass bocks
Warren White
>My daughter saw a nifty craft idea that she would like to try, but it involves drilling a hole in a glass block (like the ones you see in bathroom walls or windows) and putting a small light inside.
What kind of drill, and what method do you use to drill a hole in a glass block?
TIA,
Warren
Re: Drilling glass bocks
>I don't think glass blocks are tempered glass, which can't be drilled (I tried it one, fortunately wearing safety glasses, and the dramatic disappearance of the vent window I was trying to drill and simultaneous appearance of hundreds of little bits of glass was really exciting). Check with your supplier first.
If they're not, I think (not sure) that you can drill glass with ceramic tile bits, available at most hardware stores/big box home improvement stores. There's also a method that involves a wood or metal rod spinning in a pool grit, like valve grinding compound, retained by modeling clay or something similar. This is slow, but, I imagine, less prone to chipout.
Cheap Harbour fright Diamond hole saws
Dave Anderson (PacNW)
Dave LaPine
>I have done what bill said. It's slow but I used a chucked up a piece of copper tube in the drillpress on the slowest speed, then used some valve grind compound from NAPA and built a little dam around it with masking tape. I've also used bits from the big box store made for ceramics and stuffed a small piece of wet paper towel inside the bit to help lubricate it.
GalenV in Iowa
>Did the block really have a drilled hole or just one of the blocks they sell at the craft store that have one open edge?
The ones I have seen were all open and set on a base of some type with the open edge down over a light.
Done it several times...
John E in SC
>It's time consuming, but I've never broken one yet! I use a 1/2" diamond bit made for drilling glass or tile from the blue box (it's triangle shaped). Seems like it might have been in the $20 range, but I'm not positive. I usually use my drill press just to help with the arm fatigue - I go slow, and use lots of water as a lubricant / cooling agent - if the glass gets too hot, it will crack.
What we do is feed a string of Christmas tree lights down in the block (have to cut off the recepticle end), then take wide ribbon and "wrap" the box like a Christmas present using hot glue. Looks very pretty when lit up, and makes and very nice gift.
Warren E. White
>Thanks to all who responded. I will give it a try. The idea (and the added suggestion of John in SC) intrigues me.
Warren
oh poo. I thought this was about beer.
Victor Parisian
John E in SC
>Do a google search for "glass block Christmas presents" or something similar, and you'll get lots of info. Look under google images for lots of pics, also. I checked this last night, and saw lots of variations. May have to make some more for Christmas again this year!
