Drum sander question
Dave LaPine
>I'm partway into making a drum thickness sander using some of the plans and ideas of others that I have seen built on this site and others. A question that I have is the best way to attach the paper to the drum. If the drum diameter is 4" spinning @1725 RPM would a velcro attachment allow the paper to lift up too far from cenrifugal force and cause problems?
Re: Drum sander question
Jim DeLaney, Austintown, Ohio
>Not sure about the drum speed, but Woodmaster uses velcro on their sanders.
>I have a Performax 16/32. the drum is about 5" in diameter and there are clips at each end that hold the paper. The drum is aluminum and the cloth backed sandpaper runs against it. You have to use sandpaper that is treated to be resistant to stretching or it will expand and be loose on the drum. The clip on one end is designed to pull the slack out of the the roll. If the sandpaper is loose it "flies" above the drum. It acts sort of like a flap sander and no longer sands crisply. Edges are rounded over and the grain is sanded away in the soft spots.
The Sand Flea uses sandpaper attached with Velcro. You slide the work across the drum. Much less pressure than have the drum pressed down onto the work. I don't have any experience with the Sand Flea. Saw one at a woodworking show. I made a table that fits on top of my Performax and lets me hand sand things that won't fit under the drum.
Fred Davis
>Dave ,
if you do a little research , I think you will find the 4" drum to small in diameter.
A little reading should give you a better idea , like 5" or 6".
FredD
Dave LaPine
>Barry- I was wondering if the paper w/o velcro would work better for a thickness sander since there would be no cushion between it and the drum or am I just over-engineering this? If Woodmaster uses velcro it must work ok. Thanks alot Fred, where were you when I made my drum? Actually it's 4-1/2". Bigger would be better but it's already made. The Sand-Flee style was my original idea when I started but I think a thickness sander would be a more valuable tool.
>Dave, there has been a lot of discussion here about drum sanders. As I said, I have the Performax with an aluminum drum and no velcro.
A couple of things. The people that advocate aluminum drums claim they help to dissipate the heat generated by sanding. (What can I say? Mine seems to work, but I have nothing to compare it to.) My motor runs at 1725 and the drum is 5" in diameter.
When the belt is loose, I get "sloppy" results. It rounds over both ends as they enter and exit. It rounds the edges. I dont know, but suspect velcro would tend to cause the same effect.
If you are thinking of this as a "thickness" sander, you might be disappointed. I can and do thickness with mine, but it is very slow and tedious. It probably won't remove 1/100" comfortably in a pass, even with 36 grit paper. BUT, what it will do that my lunch box planer won't do is a beautiful job on crotch, burl, birds eye, knots, and other snarly grain. It allows me to resaw and use some gorgeous stuff that the planer would (and Has) chewed up and spit out in shards.
As with all sanding, fresh sharp paper is the key to success. You can clean the paper with the gummy stick or wash them with Simple Green and it really helps, but at some point, you have to trash the paper and get some more. I'm looking at buying in bulk to cut the cost to about 1/3. Dull paper, that's loose will sand away the soft grain and leave the harder part standing up like ridges. I think that hard drum helps eliminate this when the belt is tight. I suspect velcro would aggravate the problem. Again, I don't actually know, but I'm just say'in.
I have a two HP motor that I considered putting on my machine in place of the one HP. But it runs at 3450 rpm and the consensus here was that it would be much more likely to burn the wood.
