Old wood for chair seats (*pics)
GolfSteve in Calgary
>I've been looking for some wide, thick planks of softwood for use in making some Windsor or Shaker type chairs. Ran across two bookmarked planks on the weekend, and I bought one of them. Had the guy cut it in half to fit it into the car - 19" wide x 2-1/2" thick x 10' long. Wood is air dried Engelmann Spruce, quartersawn, with only one knot in the board. The outer portion of the tree, with the tight growth rings, is apparently instrument grade, so I'll save some of this for use in guitar project that I've been planning for several years now.
I actually wanted to buy some northern white pine or poplar for this project, but then this board came along. After buying the board, I was rereading Drew Langsner's chair making book and he does not recommend quartersawn wood for chair seats because it splits easily, but I don't expect any problems...any comments?
The picture makes the board look warped, but that is a figment of my poor photography and splicing together three photos to show the growth timeline. Interesting how the growth really slowed down as the tree aged.
Re: Old wood for chair seats (*pics)
Good haul (cute kid also)...
>I typically have had to glue up my chair seat wood. I have had some luck with Eastern White pine and Cypress, but they weren't quartersawn.
What A Story Board!
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Hey Steve, Nice to see that you dated the rings. I do that with a lot of the trees that I saw up. It can be pretty interesting as we get older, and have some memory of weather and events that can be found in the rings.
I did a quick check in a strength properties chart. The Tension Perpendicular to the grain is 350, which is actually better than most soft woods, cypress, cedars, fir, and most pine. It is somewhat softer than some of those, so would ding easier, but that can be dealt with better than a splitting bottom.
However, the numbers in this chart does not differentiate between quarter and plain sawn.
If I were you, I would cut about an inch off, then break it by hand to see how one inch resist or breaks easily. If there are some checks present due to thick / drying problems, there may be something like flooding any of those with CA glue until they are full. I am finding that to be a good way to deal with fine checks in valuable wood which has this problem. CA is so thin that you don't have to take it apart to get it to the bottom of the finest cracks.
