OT-Wireles Router for Laptop.
Ken Oakley-Sunny St. Cloud,Fla
>My wife's Dell Inspiron laptop arrived today and now we need to get a router so she can go on line. She will use it mainly for email and maybe a few websites. Need some expert advice as what to buy that wiil do the job without needing a Gov't. bailout to finance the purchase. I also have two Dell desktops, one hooked up broadband on cable sevic and one not hooked up to the internet.
Re: OT-Wireles Router for Laptop.
Ronald
>linksys at walmart is a cheap wireless router and works just fine. easy to setup too.
Rod Peterson * Ormond Beach
>I'll give you my old (couple of years) Link-Sys 4 port wireless. For some reason I had problems with it (as well as my Link-Sys non-wireless 4 port) and replaced them with a D-Link, which is working fine. With two routers not working right, I think it more of a problem with me, particularly as my son has a Link-Sys which he loves.
Anyway, I'm at loose ends Thursday afternoon, and have a need to visit CompUSA and Woodcraft in Cassellberry. Want to meet me there and pick it up?
Rod
Sounds like a plan
Dustmaker Mike
>I have a few link-sys in service at my house and a few others I set up and I have not had any problems. I will say hook all your computers to the link-sys and use it as a Firewall.
Re: OT-Wireles Router for Laptop. *LINK*
John McGaw
>Aww. C'mon. A decent wireless router is not likely to cost as much as 5% the price of a mid-priced computer; not really a bank-buster.
If you want cheap and wireless there are dozens of units available. Personally, I avoid wireless like the plague unless it is absolutely necessary -- wired is ever so much faster and more secure.
But if you really want wireless, check out this one...
Cheapskate's Wireless Router Deal
To Rod
>I thank you for the generous offer but I have to decline. First I am sure if you had no luck with the routers, I would stand less of a chance due to lack of computering skills. Secondly, like an alcoholic that has to avoid bars, I can not get within visual distance of Woodcraft. I am a recovering ToolaHolic.
Re: To Rod
>Well, it wasn't that I had *no* luck with the router. It worked fine—I just had to reset it or my DSL modem every couple of days. Same with the non-wireless. For some reason, I haven't had that problem with the D-Link. Not never, just a couple of times. The fact that it was two and that my son loves his leads me to believe the problem is probably elsewhere, but I was so aggravated at the time that I just gave up on them.
Okay on the Sirens. I'm going anyway, although I have to wear my porno mustache and sunglasses because of the restraining order…
Rod
Ric Taylor
Ric Taylor
>My wireless laptop is quite peppy and very fast, much faster than my wired desktop.
Ric
I had the same problem Rod..... *LINK*
Tim Greif - West of Chicago
>I also had to reboot my Linksys every couple days due to lockups. We finally downloaded and updated the firmware. Not a single lockup since, and it's been at least a year. The link below gives the drill.
Give it a try.
Updating Linksys Router Firmware
Bill Howatt
>If you have a good, strong wireless N signal it theoretically should be faster than a 100Mbps wired connection. It will not be faster than a 1Gbps wired connection.
If your wireless signal is marginal then it will very likely be slower than even a 100Mbps wired connection.
Bill
Walt Smith
>but most internet connections are less than 10 mb/sec, soit seems like 54 mb/sec is adequate. I agree that wired is better but pulling cable can be a pain.....
Bill Howatt
>You are correct for internet data transfer. I use my network for transferring files, often large files, so the difference is noticeable. No argument about wireless being easier than pulling wires and certainly keeps the portabiltiy of the machine intact.
Bill
