Preferred tubing for dust collection runs??
John Aniano, in central NJ...
>Hello All,
I'm planning my dust collection system and I wish to have a ~25 foot long straight run from the 2HP Jet vac unit to the various end use machines. Question - what is the preferred plastic tubing to use for such a run? Does it need to be schedule 40, heavy-walled PVC or ABS tubing, or can it be the much lighter and thinner wall (~1/8") PVC or ABS sold for septic system runs? Regardless of the tubing I use, I'll ground the system using regularly spaced screws and copper wire.
At Home Despot, I found a newer version of the thin walled plastic tubing for waste lines - it is a composite with a white/clear outer layer and a black inner layer. The diameter is 4". They told me that it was better than the solid ABS or PVC since it wouldn't crack when used for waste lines. Has anyone used this stuff for dust collection systems?
Any thoughts?
John
Re: Preferred tubing for dust collection runs??
6"
>I used 6" S&D of the 2-layer (black inner) variety. Cheap, plenty strong, and uses recycled material.
Get it at mason supply as the big boxes carry 4" (Lowe's used to handle 6" but stopped in my area)
Re: 6"
>Mark,
What does the S&D stand for? And why use the 6" tubing if the inlet of my Jet is a dual 4" diameter port? Just asking...
John
Re: 6"
Fred Davis
>Why not ask Jet for their recommendations, never hurts to ask the guy who designed it ,rather then hit or miss ideas.
FredD
S&D *LINK*
>S& D stands for sewer and drain.
I like 6" runs. You can remove the plastic housing from the Jet and hook it with large hose directly to the 6" mains.
The reason you want 6" runs is that it moves more air. Volume (CFM) of flow is very important. Bill Pentz has an excellent site - he is the guru of dust collection.
Bill Pentz DC site
Material moves more efficiently through 6"
John in NM
>Due to the higher ratio of volume to internal surface area per unit length. As JL suggested, Bill Pentz's website is a good read.
maybe
Dan Donaldson
>You need to make sure that the collector can move enough volume of air to support the 6 inch line. A smaller system may not be able to move the air with enough velocity in a 6 inch line to keep the dust suspended.
I used metal
Bill Tindall, E.TN
>My DC pipe is a medium gauge "stove pipe" material at the recommendation of the folks at Oneida. It was cheap and easy to work with. As far as diameter, what is "best" depends on the air flow. The velocity needs to be high enough to carry chips. So there is an optimum for each system. Mine starts out at 7" and winds up at 5" at the ends (designed by Oneida).
Re: 6" *LINK*
>Hi John,
You take the 2x4" splitter fitting off the inlet plate and you'll find either a 6" or 5" port. If 6", you're good to go using a 6" Fernco connector from blower housing to pipe; if 5" you'll need a 6-to-5 reducer. Ferncos, sections of reinforced rubber pipe used on drain line joints, can be found at any big box plumbing dept. Using the Fernco joint allows you easy access to the blower and pipe to clear any clogs or remove obstructions or objects that get sucked up and stuck in the impeller.
One issue with 4" pipe is that it creates too much drag on both the air and the dust stream, robbing the system of velocity. You haven't mentioned what model Jet you have, so it's CFM rating is determinative of what size ducting it will support.
The debate between PVC and metal duct owners will never die. Metal is required in industrial systems for reasons which don't apply to home and small, one-man shop situations. PVC pipe is the only material that is used to install the hundreds of thousands of whole-house vacuums in use. It's safe and more than strong enough for your shop at maybe 10-15% of the cost of metal ducts.
You can also improve your system performance by investing in a good filter bag. The pic is of my set-up out in my garage. Too small a filter bag creates a lot of back pressure robbing your system of performance. I recommend the people at the link who will tell you what you need for peak performance.
Dust Collector Bags
Bad Link Fix  *LINK*
Link
2 HP
>John,
Reread your post. The only 2hp JETs are the #1200 units which have more than enough guts to run a 6" system. They also have a 6" port under that 2x4" splitter fitting, so your connection is easy.
mm
mdclor
>I read someplace that there is no need to "ground" PVC tubing because it is plastic which is an insulator. That means that any grounding you do will only be effective for a very short distance from the screw or wire you attach. I don't have my tubing grounded and so far, no explosions. YMMV.
FWIW,
Merle
>I have a Delta 1 1/2 hp DC and use 6" S&D pipe as a main and reduce down to 4" for each machine. Works well. I can have two gates open at a time and still have good suction.
Mark's post about using a Fernco coupling was a Duh! moment for me. Did not occur to me at the time. I used a piece of inner tube. Got a used one from a tire shop for nothing and then used hose clamps to hold it in place. Come to think of it, I would do that again. Cheap and easy.
I spent a lot of head scratching time trying to fit my system together. Lowes had a limited selection of fittings. Very limited on the 6". I used 2 45's to make a "swept" elbow and a wye and a 45 rather than a tee.
Read Bill Pentz site. Its packed with information. I got into it at the time and would have made my own fittings if it had occurred to me. I'm cheap and it would have been interesting.
I intended to ground my system, but did not do it in the beginning. Later I ran a piece of aluminum foil tape inside the pipe and grounded it. Can't tell much difference.
Re: 6" tubing for DC system... *LINK*
John Aniano - in NJ...
>Mark, et al.,
Thanks for the great ideas. Mark, I think I will try using the 6" S&D pipe with the Fernco fitting. Sounds easy to me and elegant.
One slight hitch - I'm planning to make one of the "Thien" "cyclone" separators made using a 30 gallon metal trash can with a few fittings and the neat "Thien" internal baffle. Details are at Phil's site (link below). I plan to put this unit upstream (in front) of the impeller unit so the cyclone will catch any larger chunks before they hit the impeller. Thus, I need to make a 6" version of the Thien separator instead of the usual 4" versions. Other than that, I have a path to finishing this system.
Thanks!
John
Phil Thien's site
Blower Hook-up
>A common mistake in many DC systems is made at the blower connection. You need to set things up such that you have a straight run of pipe into the blower of at least 24" - no bends, curves, etc. This evens out the air flow inside the pipe and allows your impeller to get it's maximum "bite" on the air stream. For maximum benefit, you'll do well to raise your blower inlet to the same level as the output of the separater. If you can't, then situate the can far enough away so that you can drop to blower level using 45� fittings and lengths of pipe at least 2' long.
Warning: When you're finished, you may need both belt and suspenders to keep your pants on when you fire this thing up! |;-}}}}
Re: Blower Hook-up - a slippery slope indeed...
John Aniano in Central NJ...
>Mark,
Thanks for the tips, links, etc. - I'll try to incorporate as many of them as I can. Your suggestion of a mason supply in my area didn't turn up too many choices, but I did find Stevenson Supply in Mount Holly that seems to have just about all the tubing and fittings I'll need.
Tell me how, as a dedicated hand-tool user, I've gotten to this point contemplating a fairly large, if I'm to believe your comments about my suspenders, dust collection system? All I did was buy one ca. 1955 Atlas 6" planer, used it a few times, saw the mess it made and and it all went downhill from there...
Thanks,
John
Side Benefit
>No Bugs!
They get sucked right out of the boards, eggs and all |;-}}}}
