ADVERTISE HERE - FREE TRIAL
Advice on cutting laminate counter tops
riley140
>Can anyone provide advice on the best way to cut thos laminate counterrops that you but at HD or Lowes? not sure how to deal with the backs splash it would need to be two cuts. My only thought is to screw a guide to the "Waste" Side that is tall and "L" shapped to follow the Counter top accross and then down the backsplash.
Thanks in advance, any help would be greatly appreciated.
Larry
Re: Advice on cutting laminate counter tops
Glenn Madsen, near San Francisco------WebKitFormBo
>I can't say that I have the real answer, but my approach involved a jig saw and a belt sander. The belt sander cleaned up the jig saw roughness, and trimmed to meet the definitely unsquare wall. It also helped tremendously with the fitting of the sink cutout.
This week's sink, though, will deal with porcelain tile.
Dick Coers
>I've only done one, but I cut if from the bottom side with a "skilsaw" and a straight edge, then used a hand saw to finish the cut on the backsplash. The hand saw cut was off the line, then used a belt sander for that couple of inches.
I wouldn't be suprised that they could provide them cut to size these days.
Bill Wilkinson
>I recommend that you get it cut by the store.
that stuff comes at 20-30$/ft - if you screw it up, YOU get to buy a new piece.
When they cut it they put the joint slots underneath.
Yes, I know - it is sometimes 80$ per cut - that is or the mitered corners.
That said, cutting from underneath is the way to go, with the handsaw for the backsplash. I did it only when I had a piece that I had to cut myself - leftover from another job. It went well.
