OT Where can I get Outlook Express??
>I have been lamenting the fact that my hard drive failed.
In the process, I lost Outlook Express. I had been using it to manage my E-Mail through Comcast. I have Outlook setup now, but don't like it as well as I did the Express version. (It does not seem to have a "sent" file and does not seem to update the "Send/Receive" automatically.)Can anyone tell me the settings to correct these things?
So where do you get Outlook Express? What other mail management program would you recommend?
Re: OT Where can I get Outlook Express??
Alexander Grigoriev
>Outlook Express is included with Windows XP.
In VIsta, it's named WIndows Mail, which is, if I remember correctly, a separate download.
In Windows 7, they dropped Windows Mail, and left you with Windows Live Mail, which is quite half-assed. It's a separate download.
Thunderbird....
Chuck W
>Download and install Thunderbird. It's a very good mail management program from Mozilla.
Curly Smith
>Outlook Express is included in the Internet Explorer download. If you have IE installed on your machine then use a file manager to find the file: MSOE50.INF (if you have multiple instances then select the newest (it should be under C:\windows\inf)).
Then Right-click the file, and then select Install from the menu. This will install Outlook Express.
Grant Wilkinson
>To answer your questions about Outlook (not express), you can have Outlook send and receive on opening it by going Tools, Options, Mail Setup. In the middle of the window, you will see a check box to send on opening. It will also receive.
In terms of a Sent folder, I'm not quite sure what you are saying. Outlook has a Sent folder, just like Express. You should see it both in your Favorite Folders in the left hand window, and in the list of your folders.
>If I go to My Shortcuts I have In Box, Drafts, Journal, Outlet Updates. and that's all.
Any idea how to add a Sent file? I found it useful for those peopel who said, "you never sent it".
>I found msoe50 but when I clicked on it it came up and asked for the path to the msoe50.exe file (I think). At that point, I chickened out. What now?
Grant Wilkinson
>Go into the View menu and check Navigation Pane. That will open up a bar on the left of your screen showing all your folders, including Sent Mail.
If that doesn't work, we should likely take this offline, so as not to bore everyone else.
You can email me at grant4 at wilki dot ca.
Curly Smith
>What version of IE are you running? Outlook Express wasn't included after version 6 so you'd need to download and install that version (available here) and then reinstall IE8 (IE6 probably won't install over IE7 or IE8 so you'll likely have to uninstall them, just make sure that you save your bookmarks...)
Alternatively, you could download the replacement for OE Windows Live Mail
Or, you can try to make Outlook work for you. How you do that will depend on what version of Outlook you're using. You're going to need to verify that the "Save copies of messages in Sent Items folder" is selected (probably under Tools | Options, then Preferences | E-mail options). And you'll need a shortcut to your "Sent Items" folder. I can tell you how to do that in Outlook 2000 but not for the other versions. Try searching on "Outlook YYYY sent items" (where YYYY is the version of Outlook that you're using) or try a search on "Outlook YYYY tutorial". It's simple to do once you've unraveled the unnecessary complexity.
