Re: Acer Laptop Question (OT)
Dave Paine
>Even if you had an "F10" feature, which would attempt to reinstall the operating system, this would only work if the drive itself was healthy, and it sounds like your drive may not have been healthy.
There are a few key files needed for the operating system to begin the "boot strap" process. If these are corrupt, and you attempt to reinstall, the drive will attempt to write the new file over the old file, and if the physical address of the data is bad, you will still have problems.
In addition, if you have not backed up your files, you would lose data like your email address list, favourites, all "My Documents" etc. Biggest headache is when you loose the serial numbers for software which needs to be re-installed.
As for your screen, it sounds like the backlight has failed, or perhaps the technician managed to disconnect something.
I have suffered from more than my share of hard drive failures. My most recent was earlier in the year. Sometimes the drive will generate errors which are picked up by the drive's "health" monitoring system, or sometimes by the operating system - if you know where to look. I found this once, but forgot the menu's.
Most of the time "Murphy" rules and a drive can go bad with no warning.
It sounds like your drive suffered from corruption of certain files. My most recent failure also could not find the operating system. I was able to hook up the drive to my other PC for diagnosis. Turned out I had major corruption which was not fixable. Needed a new drive. Minor cost, but major headache to reinstall operating system and other programs.
