Glue for chair rung?
>I would ordinarily think about replacing the chair rung - but I would have to disassemble the chair and I don't know what adhesive they used, etc., etc.
The rung is broken near a cove. I can spread it a bit. I may be able to put a double pointed pin into the end grain. I was thinking about using a 5 minute epoxy to fill any resultant gaps. Any other suggestions?
TIA
Re: Glue for chair rung?
>Good Afternoon JL,
If I visualize correctly, the rung is snapped apart rather than split, and you do not have to mate long grain to long grain by using yellow glue. Epoxy and internal pins may do the job. Depends on the guage of the pins, and how well they are centered and anchored. Can you remove both parts of the rung? If the chair has any value, or oft-used utility, I would turn another rung, assuming you can spread the structure far enough apart to engage the rung's tenons.
George
JOHN l BLUE
>Titebond oughta have a cure.
>JL I do a lot of repairs like this. I use All-thread rod for my dowels. The threads help hole the epoxy. I drill the hole a hair oversize. Put 5 minute epoxy in, insert the dowel and clamp back together. I use alcohol to wipe off the excess epoxy. It works great.
I use the 5 minute epoxy because it seems to have more flex than slower drying version. I don't know if this is true or not but I've turned through a lot of epoxy over the years and the 5 minute is definitly more pliable when cured. I've also used it for a lot of cross grain dowel joints when putting handles on my hand mirrors. I haven't had any failures that I know about since going to the 5 minute epoxy and cutting slight notches in my dowels.
1/8"??
>I can get some that size.
