Router Bit Question
Router Bit Question
Router Bit Question
T Rex
>A friend of mine has asked me to take his fake raised panel kitchen cupboard doors and put glass in them where the fake raised panel was.
The doors are solid core with a veneer on the outside. He wants me to cut in the groove that outlines the fake raised panel.
From the outline of the fake raised panel to the center of the groove is ��.
I have taken a drill, drilled a �� hole in the panel, and used my jigsaw to cut the panel out.
Now I believe I want to take my router and a straight bit with a bearing �� larger than the bit so that I can follow the outline of the fake raised panel.
Is there such a bit & what is it called?
How would you have accomplished this task?
TIA,
Tom
Re: Router Bit Question
Re: Router Bit Question *LINK*
pecker
>Any piloted bit I've used had the bearing equal to or smaller than the cutter's width. I don't quite understand the cut you're trying to make, but if you really need the bearing to be larger than the bit, you can buy bearings separately to suit your need. See the link below at MLCS.
http://www.mlcswoodworking.com/shopsite_sc/store/h
Ken Krawford
>Could you not put a 1/2" OD collar on your router and use a 1/4" diameter straight bit and accomplish what you're after?
Lee Grindinger
Caution, this could turn into a disaster
Lee Grindinger
>The core in solid core sheet goods are often NOT edge glued relying entirely on the veneers for strength. The solid core pieces are often left with gaps so they can behave as solid wood does without destroying the veneer or altering the size of the panel.
If you rout out the center leaving 2" or 3" "rails" at top and bottom the strength of what's left may not be enough to support the glass or stay flat, or even be truly sound.
I will caution you about a potentially friendship ruining, expensive frustrating, and time consuming futility that may result from this project.
However, if you choose to undertake this project I wish you the best of luck,
Lee
not sure about "often", there's still a problem
Bill Tindall, E.TN
>I have had two experiences with solid core (AKA lumber core) plywood. In one case I knew the owner of the factory that made the cores using various hardwoods. They were glued up as 4 x8 or 4 x 10 panels, planed (with a 4' wide planer!) and sanded. I used to buy seconds from a near by hardwood veneer plywood factory. Their cores were glued panels, typically luan. I don't see how the plywood panel would have any strength or rigidity unless the panel was glued. However, if it is Chinese plywood then all bets are off.
However, even with a glued panel the door is going to be weak because of the grain orientation at the corners. A tiny stress will break it.
It seems to me that it would be best to just order new doors from the many places that sell doors.
