Deft Lacquer on kitchen cabinets
Bob Boswood
>I have built a couple kitchens, finishing them with sprayed water based poly. They are both holding up nicely after uears of use. I am currently doing another kitchen and because of desired color match am wanting to spray these with deft lacquer. The amber tone of solvent based finish helps me achieve color match. I am pretty sure this finish is durable, but having never used it before, I would appreciate the oppinions of this learned group if you do not mind. I start sanding tomorrow so I should be ready to spray in 3 weeks, just kidding, god I hate sanding. The wood is all solid cherry and cherry plywood. Thanks in advance.
Bob in AK.
Re: Deft Lacquer on kitchen cabinets
Re: Deft Lacquer on kitchen cabinets *LINK*
>If you want solvent lacquer, especially in a high-use area like a kitchen, nix the Deft and get some M.L. Campbell product.
If, however, you'd like to stay with your proven waterborne and still get color match, go over to Homestead Finishing and get some TransTint Amber. Won't take much in the way of mix/testing to get an exact match that will stay matched over time. While you're there, check out (or ask Jeff by phone) about the General Finishes Enduro Polies. Add some cross-linker and you've got something with serious durability!!
mm
HomeStead - Jeff Jewitt
not the best choice
Bill Tindall, E.TN
>Investigate any of the conversion varnish products.
I don't know what you mean by color matching in this case but it is fraught with peril in the case of cherry if you are trying to get some new piece of cherry to look like some old piece, temporarily. If you are just trying to avoid the crappy luster of water based finishes than any solvent based finish will be satisfying. I can't tell the difference between conversion varnish and nitrocellulose lacquer appearance. There is a huge difference in durability. Your local Sherwin Williams store will have technical data on all these products, and, they may even know where to find it if they sell to cabinet shops, or be clueless if they don't.
dont do it
jared
>I used deft lacquer on my kitchen cabinets and have regretted it ever since. Deft does not hold up to water, steam or heat. There are better choices. I still use deft for a lot of things but not on cabinets. Jared
even precat lacquer will not hold up
Dick Coers
>I would not use any lacquer in a kitchen. I used M.L. Campbells precatalyzed lacquer on my kitchen and it has failed on the doors under the sink/next to the dishwasher. Use poly. Catalyzed varnish is the best, but the chemicals scare me. I used it when I was business years ago, but really hated to.
Re: even precat lacquer will not hold up
Bob Boswood
>Thanks for the advice. Guess I'll stick with what I know works. Water base it is.
Bob in AK.
Fred Davis
>Bob ,
some of the information your getting is not exactly true.
I have been a Cabinet maker for many years and nearly always finished my own stuff after I learned how.
For years the finish was Nitrocellulose Lacquer which most shops used.
Then came along CAB or Pre Catalyzed Lacquer which is a major improvement over the NC Lacquer in that it requires a Vinyl sealer underneath which is far and away the best moisture holdout available in finishes and the Lacquer itself is much tougher.
That being said , I did dozens of kitchens using NC Lacquer without any call backs on finish.
Your idea on using Deft has a couple of problems , since it is formulated to be a Brushing Lacquer, it's drying time is retarded , which may give you runs and sags on vertical surfaces.
Deft in a spray can while giving a fair job , would be a expensive way to on a set of cabinets.
Any finish regardless of quality or resistance to wear and tear is not a substitute for poor house keeping.
FredD
So, what is typical?
Tony - Memphis
>Our cabinets are from a local cabinet company. Semi-custom. I don't know what is on them, but after eleven years, they still look brand new. We treat them pretty well, but still. So, what do most cabinet companies use?
My dad swears by Deft. He used it on a whole house full of antiques that lived through three boys! He loves to tel the story of on a Halloween in Germany in the mid 70's, someone put a garden hose in the basement window. Our dining room tabletop was down there with a few fresh coats of Deft on it...got soaked, but nothing happened. I like Deft too, but I have to use it outside. That is some nasty stuff - even with a mask. Haven't tried the water based yet.
Tony
